Old 09-03-20, 02:31 AM   #1
bikeguy
Default Banjo Switch Size
Neeed Help on knowing which size banjo switch needed for my SV650s K9 model (09)
1mm or 1.25mm???
Looked everywhere and cant find any information on it.
Old 09-03-20, 07:52 AM   #2
admin
John T
admin's Avatar
Default Re: Banjo Switch Size
Not sure what you mean by banjo switch.
Old 09-03-20, 08:52 AM   #3
bikeguy
For the rear brake switch. Instead of coil and spring. It’s a pressure switch I think for the brake light.
If that helps at all.
Old 09-03-20, 09:20 AM   #4
admin
John T
admin's Avatar
My bike was older and I had the old style switch, the spring and plunger type. I'm sure someone on here with a later model can help.
Sent from my Moto G (5) using Tapatalk
Old 09-03-20, 09:43 AM   #5
Chris_SVS
Chris_SVS's Avatar
Master cylinders F+R are 1.0 the calipers are 1.25 both M10
Chris_SVS is offline   Reply With Quote
Old 09-03-20, 09:57 AM   #6
Seeker
Seeker's Avatar
Is it non standard because the parts fiche shows it as a mechanical switch:
https://www.fowlersparts.co.uk/parts...s-sv650a-k8-k9
(part #17)
My 2016 AL7 also has a mechanical switch
2016 SV650AL7
2023 GSX-8S
Old 09-03-20, 10:04 AM   #7
Chris_SVS
Chris_SVS's Avatar
A pressure switch like that would be fairly common on offroad stuff or custom builds. It's definitely not standard, but also why not?
Would be cheaper than replacing the M/C
Curvy banjo bolt thread size? froymot SV Talk, Tuning & Tweaking 3 25-03-14 06:38 PM
rear brake banjo size barwel1992 SV Talk, Tuning & Tweaking 8 13-12-09 12:12 AM
Rear Banjo Bolt Size Sideshow#36 SV Talk, Tuning & Tweaking 2 06-07-09 10:31 AM
Rear M/C Banjo size, 1.0 or 1.25 Ter SV Talk, Tuning & Tweaking 5 08-11-06 12:34 AM
What size is the banjo for the rear master cylinder? northwind SV Talk, Tuning & Tweaking 11 27-04-06 11:08 PM
