Old 28-02-05, 09:14 PM   #1
SPUD
Default regulator/rectifier
Got back from work and battery cooked,i mean it stinks!!!red hot and steaming. .it has to be the rectifier doesn't ?????.do any of you know a breakers or the like near hertfordshire.
any help is most welcome.
kind regards all
Old 28-02-05, 09:37 PM   #2
21QUEST
21QUEST's Avatar
What model have you got . I might have one for a K2. Let me know by via PM if it's what you are looking for.
Ben
Nemo me impune lacessit.
Old 28-02-05, 10:19 PM   #3
Mike1234
I've got one for a K3.
Old 01-03-05, 06:36 AM   #4
SPUD
it's a 2000(w) 650
Old 01-03-05, 09:21 AM   #5
embee
embee's Avatar
not sure about the K3, but as far as I'm aware the 2000 model should be the same as the K2 mentioned above.
If the worst comes to the worst, someone here once posted a link to
http://www.patternparts.net/
Old 01-03-05, 12:32 PM   #6
iprideaux
Default Don't ride the bike again until you've fixed it.
When the battery boils dry, the supply voltage will go up and my blow up your CDIgnition and/or your clocks and/or pretty much anything else.
It happenend to me.
Battery + CDI + RegRect + labour = £500 + +
Old 01-03-05, 02:09 PM   #7
SPUD
CHRIST !!!!!!!! ,well luckly it hasn't gone that far??????????
Old 01-03-05, 02:22 PM   #8
Mike1234
I've got a couple of spare CDIs for the early models so it wouln't have cost *that* much
Old 01-03-05, 03:10 PM   #9
SPUD
does a k2 fit the 2000 model then,cause i hav'nt a clue
Old 01-03-05, 09:07 PM   #10
21QUEST
21QUEST's Avatar
IIRC all up to K1 use the same(two connector blocks coming out of the rectifier) while the K2 has one connector block.
Check your knacked one and see how many connector blocks you have.
Ben
I need a Rectifier / Regulator. Marv Stuff Wanted 3 19-08-08 12:43 PM
Regulator-rectifier beaniebikerbabe SV Talk, Tuning & Tweaking 15 27-05-08 12:33 PM
Rectifier/regulator Gordon B Stuff Wanted 12 02-01-08 11:00 PM
Regulator/Rectifier? Biker Biggles SV Talk, Tuning & Tweaking 22 31-05-07 08:55 PM
K2 regulator/rectifier, new in box northwind For Sale - SV's and SV related items 0 22-02-07 09:14 PM
