Old 30-05-05, 04:57 PM   #1
branny
Default bike doesnt start first time when cold
ive had my 650 about 2 months now....
it used to start with full choke first time and every time, with no throttle, just a button press.
recently i have been having slight trouble with it, and having to give a slight blip of throttle to get her started, the idle speed then raises and is fine from then on....
its not a big issue, but i like things to be right
any ideas?
Old 30-05-05, 05:34 PM   #2
Scoobs
Try with not as much choke. It might not need it now.
Is it due a service? Plug, filter etc....condition, plus carb or throttle body balance may help.
Old 30-05-05, 05:52 PM   #3
tricky
Is your idle speed set correctly ?
I was having the same problem, my idle speed was set too low.
Set it correctly (1300rpm on a K1) and it starts great now.
Old 30-05-05, 06:05 PM   #4
branny
idle speed is fine cheers......
shouldnt need a servise..., but im gonna check plugs soon.
ill try it with less choke, that sound slike a good idea... perhaps flooding it a little.
cheers.
Old 30-05-05, 06:11 PM   #5
wheelnut
mine starts without choke most of the time, if its snowing and it wont start, I use the car :P
It shouldnt need any or hardly any choke between March and November, unless you live in Finland
Cold oil, painful start billboot SV Talk, Tuning & Tweaking 11 23-10-07 10:27 AM
Bit cold this morning, time to adjust the idling speed! Kinvig SV Talk, Tuning & Tweaking 11 22-11-06 01:44 PM
New spark plugs - bike doesnt run as well rich_r Bikes - Talk & Issues 12 30-10-06 05:14 PM
Noisey sv from cold start steveg SV Talk, Tuning & Tweaking 0 16-05-06 09:40 PM
Difficult cold start (and loose exhaust pipe) owennewo SV Talk, Tuning & Tweaking 10 18-11-05 07:01 PM
