Old 30-11-05, 08:58 PM   #1
svpilot
Default New clocks
I'm just thinking ahead really...
My clocks are in a bazillion pieces at the moment (mostly scattered along the A2)
What's the correct thing to do regarding the mileage, If I replace 'em?
Cheers...
Old 30-11-05, 10:22 PM   #2
hall13uk
you will have to start again i believe, & it will be indicated on your v5 i think
bit vague i know but i am not 100%
Old 01-12-05, 02:05 AM   #3
TSM
The Sick Man
TSM's Avatar
get a second hand set of clocks which have less millage on them, then you can run the millage forwards to the correct ammount. To change the millage i guess that some sort of contraption would have to be made to turn the wheel for some time, but i dont know if there is a easier way. You can put millage forwards not back AFAIK.
You will have to make sure that it at least has more millage than the last MOT cert otherwise you could be convicted of falsifying the millage unless you declare correctly to the new purchaser all the details.
Old 01-12-05, 05:31 AM   #4
busasean
i've got a set with 16k off a 1999 curvey (faired) if you want to make me an offer!
Old 01-12-05, 09:02 AM   #5
Brucey
I can program Busa and the K3s on never tried an ealier model but sure it cant be that tough of a nut to crack.
If you know anybody with good surface mount skills you could remove your old eeprom and fit it to the replacment clocks job done.
Old 01-12-05, 12:40 PM   #6
svpilot
Cheers but my bike's naked!
Hmmm there's a thought. I work with electronics myself (pcb designer) I will talk to the guys at work, cheers.
Old 01-12-05, 01:23 PM   #7
Brand New
Hello there...
I have just written off my SV650, it's a 2000, and has untouched clocks.
The problem is that I had different tyres fitted to the bike and the speedo didn't work, meaning that there is only 3333miles on the milo.
Hit me up if you'd like some pictures.
Thanks,
Blake.
Clocks or no Clocks Demonz SV Talk, Tuning & Tweaking 15 04-07-08 03:55 PM
Clocks jon holt SV Talk, Tuning & Tweaking 5 04-05-07 01:04 PM
clocks dirtydog For Sale - SV's and SV related items 0 09-03-06 05:14 PM
SV Clocks nitro111 SV Talk, Tuning & Tweaking 0 07-08-05 09:19 PM
Which clocks? gc350 SV Talk, Tuning & Tweaking 3 30-06-05 11:01 AM
