Old 08-02-06, 11:48 PM   #1
socommk23
Default clunk when turning off!
anyone else had a problem with the sv clunking quite loud when you turn it off sometimes? what is it? how can i fix it? how much it cost?
please help!!!
Old 08-02-06, 11:59 PM   #2
thepyrofish
Mine does that too! But only when it's cold, it seems.
Old 09-02-06, 05:35 PM   #3
embee
embee's Avatar
I may be wrong but this is a possible which I suspect to be the cause.
When you switch off an engine it will spin down under inertia until eventually it reaches a compression stroke which the inertia can't overcome. If it comes to a stop near the top of compression it will "bounce" back a little.
The starter has a roller type clutch in it (usually), so when the engine turns backwards it picks up on the clutch and drives the starter gear train backwards. I suspect this is what gives the clunk.
As I say I'm open to be proven wrong.
If this is the case, then there's nothing to be done, they're all like that sir.
Also it'll be much more likely with a twin than a L4 due to the size of the cyliders (i.e. how strong the bounce "spring" is) relative to the engine friction.
Old 11-02-06, 02:57 AM   #4
socommk23
cool
cheers for the insight
was worried there might be teeth missing on the starter clutch wheel
Old 11-02-06, 05:52 PM   #5
philipMac
Oooh. Nice lid sir.
Thats the Bandit, yeah?
How do you find it, weight and comfort wise?
Old 11-02-06, 06:32 PM   #6
Iansv
Mines always done it... Never really worried about it
Old 11-02-06, 06:46 PM   #7
Stig
I used to worry about. It's the first bike that I have ever owned that I can remember doing it.
Clunk noise James SV SV Talk, Tuning & Tweaking 13 14-05-09 09:35 PM
Clunk DarrenSV650S SV Talk, Tuning & Tweaking 9 26-10-08 04:25 PM
Clunk When Braking. Alastair SV Talk, Tuning & Tweaking 6 23-08-07 05:02 PM
Clunk clunk (yes, again) clunk clunk under braking branny SV Talk, Tuning & Tweaking 3 30-08-06 03:42 PM
clunk in forks riktherider SV Talk, Tuning & Tweaking 25 07-05-05 03:18 PM
