View Poll Results: Is fitting a cooling fan to the Regulator rectifeir worth while
Yes 0 0%
No 3 37.50%
Can't hurt 5 62.50%
What do they know, they are only Aussies!!! 0 0%
Voters: 8. You may not vote on this poll
Old 27-04-06, 06:25 AM   #1
Tris
Default Alternative Regulator/Rectifier solution
Having been through the dodgy rectifier problem, AGAIN I've been searching for a more permanent fix
I found this on our sister site in Aus http://www.svdownunder.com/forums/index.php?topic=749.0
They know a thing or two about heat and it is generally accepted as one of the causes of electronic component failure
Wot you all think?
Tris
Old 27-04-06, 08:25 AM   #2
TSM
The Sick Man
TSM's Avatar
Err, dont think so realy in the UK, our weather is not as hot as theirs. Mabey if you had underseat pipes or high levels right next to the regulator.
Old 27-04-06, 11:51 AM   #3
andy
not sure on this one, it wont hurt but I dont know how much difference it will make.
I think the basic problem is crap reg/recs - heat may contirbute to early demise but I suspect it will happen anyway.....
Old 27-04-06, 01:14 PM   #4
Interesting idea, a few years ago I had a GSX550 which was fitted with a very similar reg/rec as more modern Suzukis are, it was originally fitted in the middle of the bike just at the back of the tank, which is of course not an area that received much airflow. Well surprise surprise, reg/rec failures, the mod on the ever so slightly later bikes was longer wires and the bracket in a different spot - out in the airflow. Guess what? No difference, still reg/rec failures.
A fan *might* make a difference, I think it's impossible to really know, true it can't do any harm, but if you fit a better unit it'll be more reliable anyway.
Old 27-04-06, 01:15 PM   #5
Viney
Does such a unit exist?
Old 27-04-06, 01:33 PM   #6
TSM
The Sick Man
TSM's Avatar
GSXR SRAD regulators are nearly twice the size of the SV one, mabey they are better.
What about bolting the regulator behind the rear shock onto the undertray. Ive seen some bikes like that such as the SRAD where its mounted to the back of the frame and also acts as a heatsink.
Old 27-04-06, 02:29 PM   #7
timwilky
timwilky's Avatar
I got one of a CBR6RR, apart from having to change the connectors it fitted perfectly.
Just buy a better RR
Not Grumpy, opinionated.
Old 27-04-06, 02:42 PM   #8
A few SV Rider guys have fitted PC fans to their reg/recs, they're rather handily 12V. Does it work? Who knows. There's a guy on Visordown that swears by adding a seperate earth for the r/r on Suzukis. Does that work? Maybe
Old 28-04-06, 06:14 AM   #9
Tris
SVdownunder also has a thread on that solution which they apper to like
I saw that so I checked for continuity between the case and every wire coming out of the RR and found nothing, so I can't see how it could
So overall it looks like the jury is still out.
I've gone for a better quality RR so hopefully that will help I'd rather spend theŁ70 on fuel than Cr*p regulators
Tris
Old 28-04-06, 07:36 AM   #10
But it didn't work, if there was a change in the amount of duffed RRs I couldn'r spot it, I got just as many phone calls from people with charging probs before and after.
No.
Why faff? There's a recognised and easy fix for this problem - get a better RR - breakers yards are heaving with snotty old CBRs, just fit one and forget trying to reinvent the wheel.
Rectifier/regulator Gordon B Stuff Wanted 12 02-01-08 11:00 PM
Onboard alternative - everyones pocket! (video solution) Blue_SV650S Bikes - Talk & Issues 42 21-10-07 07:54 PM
Regulator/Rectifier? Biker Biggles SV Talk, Tuning & Tweaking 22 31-05-07 08:55 PM
K2 regulator/rectifier, new in box northwind For Sale - SV's and SV related items 0 22-02-07 09:14 PM
Where to buy a SV regulator/rectifier? falc SV Talk, Tuning & Tweaking 8 17-08-05 09:43 PM
