Old 24-06-06, 07:55 AM   #1
bobit69
Default Fork Oil Replacement
Can you replace the oil, without taking the forks off the bike as the Haynes manual says?
Old 24-06-06, 08:48 AM   #2
BillyC
BillyC's Avatar
Yes you can, but the real question is - do you want to?
For those that have removed the stock oil, and seen the sludge that comes out, I think many would agree that there's no real substitute for actually removing the fork and allowing it to drain for 10 minutes before refilling.
Sucking the oil out using any method, isn't going to get it all out, and measuring the final air gap when refilling is a bit trickier too.
Old 24-06-06, 09:19 AM   #3
Stig
There are only two ways to properly drain your forks of all oil and residue. The first is to remove your forks from the bike, take out the internals and drain upside down.
The 2nd is to leave the forks fitted to the bike, take out the internals and turn the bike upside down.
I know which one that I do.
Old 24-06-06, 01:14 PM   #4
Mark_h
Mark_h's Avatar
Just had mine replaced (2001 17,500 miles) and the difference is amazing. Feels much more planted into corners. Cost £60 by local suzuki dealer.
Minister for Sustainability
Old 24-06-06, 03:53 PM   #5
No.
Not if you want it to be anything like right.
Old 24-06-06, 06:59 PM   #6
BillyC
BillyC's Avatar
Originally Posted by Sid Squid
No.
The Almighty Emperor Squid has spoken
Old 25-06-06, 01:33 PM   #7
embee
embee's Avatar
Fork spring replacement. St0rmer66 SV Talk, Tuning & Tweaking 58 04-08-08 08:43 AM
Replacement Fork Springs Cam_73 SV Talk, Tuning & Tweaking 3 07-01-08 10:35 PM
Fork Seal Replacement Luckypants SV Talk, Tuning & Tweaking 11 18-02-07 03:40 PM
Fork Seal Replacement Luckypants Bikes - Talk & Issues 1 17-02-07 07:11 PM
SV650 K3 fork replacement nicollow SV Talk, Tuning & Tweaking 10 05-08-06 05:31 PM
