Old 23-02-07, 10:59 AM   #1
amuli
Question Installing LED indicators
I bought a new undertray from Ermaxuk. The undertray has the LED indicators built in. The kit came with a resister to slow the indictor blinking down to the normal speed. Only problem I have is that I havent got a baldies how to fit it, and it came with no instructions. The resister has 2 red wires and a black 1. Anyone have any ideas?????
Old 23-02-07, 11:01 AM   #2
Viney
Default Re: Installing LED indicators
Interesting. A resistor should just have 2 wires! You wire it across the two wires from the leds. Thats how you normaly do it. 3 wires, havent the foggiest. Sorry
Old 23-02-07, 11:05 AM   #3
amuli
Maybe I was wrong in calling it a resister. Would it be a relay or something. The instructions from ermax were none existant
Old 23-02-07, 11:22 AM   #4
Luckypants
Luckypants's Avatar
It probably is a resistor, as LEDs have lower resistance than bulbs and this causes the flasher unit to speed up. Post up a piccie and we can soon tell ya what it is.
Old 23-02-07, 11:28 AM   #5
embee
embee's Avatar
sounds like it might welll be a different relay suitable for the low current draw of LEDs, like this sort of thing (only with wires attached??)
http://www.ultraleds.co.uk/product_i...8bb3fd1566beec
Old 23-02-07, 01:37 PM   #6
gettin2dizzy
its a resistor yeah. But as the black is a negative you only need to connect it once. Put the resistor after the indicators and connect each red wire to the negative coming off the indicators. Then connect the black back to either of original negative wires.
Old 23-02-07, 01:52 PM   #7
i give up with doing this and put the normal indy on.
Old 23-02-07, 01:56 PM   #8
plowsie
sorry to drag the thread away but can anyone tell me how to fit oxford universal indi's at the front do i take the original connector off?
Old 23-02-07, 02:00 PM   #9
i cut it off and just used male and female spade connectors.
Old 23-02-07, 02:04 PM   #10
amuli
Im thinking about doing wat Kwak zzr advised. With all this hassle I will prob get pulled by the filth 5 mins after leaving the house
problems installing headlight cannonball SV Talk, Tuning & Tweaking 0 12-06-08 09:07 PM
installing airbox after inspecting carbs dhtmldude SV Talk, Tuning & Tweaking 7 30-01-08 04:03 PM
installing full system - advise r4ce_e3nd SV Talk, Tuning & Tweaking 4 20-09-06 07:24 PM
Installing a tail tidy - How? BIKER-DENE SV Talk, Tuning & Tweaking 3 15-06-06 12:31 PM
When installing a new chain.... Scoobs SV Talk, Tuning & Tweaking 4 12-09-05 08:31 PM
