Old 12-04-07, 10:05 PM   #1
hovis
Default whats wrong with the forks?
it seems everyone uprates the front suspension in one way or another, but what is actuly wrong with it? mine seems fine, maybe they have been done ?
how can i tell if i have uprated springs
Old 12-04-07, 10:27 PM   #2
Born again
Default Re: whats wrong with the forks?
They want to upgrade them to ohlins because they are the closest to yellow but go for gixer's coz they are cheaper but forget to paint them the fastest colour..............YELLOW........
Old 12-04-07, 10:45 PM   #3
Something like that
The forks are basic, basically... The springs are too soft for a lot of fat british people, and the design means that the damping's quite crude. Also, the rebound and compression damping are both controlled by the oil viscosity which means you can't adjust one without impacting the other. They're a bit light on compression damping for most folk as well, which is why we often change the oil. Better suspension has cartidges- basically valves- which offer finer control and also seperate control of different sorts of damping, so you can add compression damping without also adding rebound. This is good.
Nothing actually wrong with them at all, though- just that they're the weakest part of the SV, with a lot of bikes you can't upgrade one bit without showing up something else- Bandit 6 for instance, has roughly the same forks as the SV but if you massively upgrade them the chassis becomes an issue, and the weight. With the SV, upgrading the suspension really pays off- don't let anyone tell you it's needed though, unless you weigh 15 stone
Old 12-04-07, 10:54 PM   #4
Luckypants
Luckypants's Avatar
.... unless you weigh 15 stone
Thanks Northy! I don't any more though!
Parking in the city - whats wrong with scooterists and BMWers? stuballs Bikes - Talk & Issues 13 06-03-09 11:30 AM
Internet Explorer- Whats wrong with it? SV-net Idle Banter 16 28-12-08 01:52 PM
sooooooo, whats gone wrong then....... Wideboy Idle Banter 31 27-12-08 10:48 AM
Different coloured oil in forks... Something wrong? mc_phers0n SV Talk, Tuning & Tweaking 6 02-06-08 05:18 PM
whats wrong with kids today steveg Idle Banter 52 19-12-07 12:31 PM
