Old 27-04-07, 08:45 AM   #1
Grinch
Default Correct Headlight alignment
Now have I got this correct, to align you headlights correctly you need to park about 25 ft (7.62m) from a wall. Then the Headlamp centres not more than 850mm above the ground.
I'm having trouble finding specific information for bikes, it all seems to be for cars, but I imagine its all the same.
Old 27-04-07, 08:47 AM   #2
21QUEST
21QUEST's Avatar
Default Re: Correct Headlight alignment
Haynes manual(if you've got one) should have all the information you need .
Ben
Nemo me impune lacessit.
Old 27-04-07, 08:47 AM   #3
Grinch
Doh!... never thought of that.
Old 27-04-07, 09:32 AM   #4
MitchC
Hey,
Did you learn anything? I just figured out HOW to adjust the beams, now I just need the "dimensions"...
Thanks,
Mitch
Old 28-04-07, 07:53 AM   #5
kcowgergmm
how do you adjust a point S
Old 28-04-07, 10:04 AM   #6
MitchC
Hope this helps.
Mitch
Old 28-04-07, 10:20 AM   #7
rictus01
rictus01's Avatar
Don't know if it's changed, but it used to be an MOT fail if it was to high, but you'd generally get away with it if it was to low, so if in doubt, adjust it down, do the MOT and then take it out at night and put it where you need it, not very scientific, but if it works
(Oh and before anyone points it out, yes I know they measure between two marked lines )
Cheers Mark,
Wheel alignment problem. smrgup SV Talk, Tuning & Tweaking 9 08-05-09 01:49 PM
Handlebar alignment keith h SV Talk, Tuning & Tweaking 3 28-06-08 04:13 PM
Rear wheel alignment Maestro SV Talk, Tuning & Tweaking 18 05-01-08 05:46 PM
Wheel alignment, again muffles SV Talk, Tuning & Tweaking 4 29-07-07 12:26 AM
Wheel alignment Ratty SV Talk, Tuning & Tweaking 9 11-07-06 07:57 AM
