Exhausts Post your own reviews, opinions and experiences on this subject.
Old 03-05-07, 06:46 PM   #1
jay boi
Default cutting off exhaust
could any1 enlighten me on this. n how do i do it?
much love
jay
Old 03-05-07, 06:50 PM   #2
sarah
Default Re: cutting off exhaust
mark on it where you need to cut and saw it off, we used a hack saw
Old 03-05-07, 06:51 PM   #3
jay boi
ooo. is there anywere special its needs to be cut off? and how does it all go back together again? :S
Old 03-05-07, 07:01 PM   #4
sarah
yes, the instructions from our fuel can said cut it 50mm after the weld (i think).
if you want to put the original can back on you'll need a link pipe.
prolly worth a search if you have any more questions about this.
Old 03-05-07, 07:02 PM   #5
jay boi
ok cheers though m8y
Old 03-05-07, 07:09 PM   #6
fizzwheel
fizzwheel's Avatar
Did you not get any instructions with your can.
Distance will vary depending on the manufacturer, its normally between 40 - 50mm, measured from the weld
See below, marked with the red arrow.
You want a good quality blade in a haxsaw or an angle grinder. Cover up your swing arm with something to protect it from over enthusiastic cutting / sawing, Also take care you dont cut your heel plates.
Oh and measure twice, cut once.
Cutting the Exhaust! hoppy34 SV Talk, Tuning & Tweaking 6 22-07-07 10:33 PM
Cutting off exhaust.. StreetHawk Exhausts 12 29-04-07 09:50 PM
Cutting exhaust gemm1984 SV Talk, Tuning & Tweaking 14 30-07-06 06:31 PM
Cutting exhaust wtdafk Bikes - Talk & Issues 1 29-04-06 03:30 PM
Cutting my exhaust buell Exhausts 5 14-02-06 05:30 PM
