I can't seem to find an answer to this, do i need a new chain if I swap to 14-47 from standard? The chain I have is quite long (i.e. the wheelbase is nearly as long as the swingarm allows), but I'm not sure how many links.
Also, anyone know of a supplier that will send out of the UK? Thanks in advance! |
I don't know about delivery outside UK, but I'm sure it wouldn't be a problem. Try B&C Express.
To answer your question, you're going up 1 on the back, down 1 on the front. The down on the front is the same as 2 on the back, so in effect, you're loosing 3 teeth on the back. This means a standard length chain will fit no problem, but because you're going down in teeth, a standard length chain will leave you with less room for adjustment by default. I think the standard chain is 110 links? Might be worth looking at 108. Talk to B&C about it, they know their stuff, seriously. |
#3 | |
I'm not sure I understand your maths though! If I go up one on the back, that's +1, then down one on the front, that's -2, isn't that a total of down 1 on the back? Also, Is the standard sprocket 46? It's a naked curvey. I'll talk to B&C, you're not the first person to say good things about them! Thanks for your help. |
Sorry yea, maths was wrong. The standard rear on my pointy S is 46. On a curvy, I don't know unfortunately. So from my perspective, going up 1 on the back (previous post assumes down one
![]() Overall effect of missing a tooth on the back. This means that by default, you'd loose a little chain adjustment, but not much (1 tooth's worth) on a standard chain. |
#5 | |
I'm confused, I thought that going down a tooth on the front was roughly the equivalent of going up two on the back?
Is this right? |
#7 | |
Chain and sprocket | CodeJACK | Hardware | 5 | 18-04-08 01:24 PM |
Need a new chain and sprocket... Which? | sv_rider1990 | SV Talk, Tuning & Tweaking | 33 | 04-04-08 07:05 PM |
520 sprocket with 525 chain? | charlie13 | SV Talk, Tuning & Tweaking | 10 | 31-10-07 08:38 AM |
Sprocket/Chain | Mr. Bob | SV Talk, Tuning & Tweaking | 2 | 03-05-07 08:43 PM |
Chain and Sprocket | Ernie B | SV Talk, Tuning & Tweaking | 6 | 04-05-06 12:35 PM |
