Old 11-06-07, 09:05 PM   #1
Peeyabbs
Default SV650 Clocks
Just new on here and to the SV, I have bought a bike which was faired but was dropped and modded to be an unfaired one, problem is that the faired clocks are still on and look, in my humble opinion, a bit odd. Does anyone know where I can get hold of a set of clocks from an unfaired model, plus, do they have the same connection for the wiring, or as an alternative, is there a bikini fairing about that will look ok.
Old 11-06-07, 09:11 PM   #2
BILLY
Default Re: SV650 Clocks
Welcome to the forum Which bike have you got Curvey or pointy?
Old 11-06-07, 09:14 PM   #3
rictus01
rictus01's Avatar
Welcome Peeyabbs,
Just a couple of things that might help you out, try adding your location to your profile (others will know what area you're in) also it always helps to say which model bike you have when asking for advice (curvy 99-02/ pointy 03-present).
I'd guess you have a curvy as the clocks are the same for naked/faired on the pointys, and the answer is no the wiring is slightly different (mutli plugs) between the two, so you'd need a naked front loom, naked curvy clocks are a little rare, so you might have to go new or aftermarket (which isn't going to be cheap).
Powerbronze do a range or smallish nose fairings which could work.
Cheers Mark.
Old 11-06-07, 09:16 PM   #4
Peeyabbs
By pointy I guess you mean the faired one, it was faired and is now not, it has twin headlights and the faired clocks.
Old 11-06-07, 09:21 PM   #5
rictus01
rictus01's Avatar
as above frame and bodywork redisgned for 2003, naked and faired available in both models.
Old 11-06-07, 09:22 PM   #6
Peeyabbs
Ah, Now I know what a pointy one is, so mines a curvy, thanks for the advice.
sv speedo and rev clocks... advice? - sv650 99 curvy mikeSV SV Talk, Tuning & Tweaking 11 01-03-09 06:04 PM
Wanted, SV650 K6 clocks and fairing bracket weecorey Stuff Wanted 7 04-09-08 10:14 PM
Streetfighter clocks - suitable for your Naked SV650 etc... on ebay Ter For Sale - SV's and SV related items 2 07-07-08 10:19 PM
Clocks jon holt SV Talk, Tuning & Tweaking 5 04-05-07 01:04 PM
SV Clocks nitro111 SV Talk, Tuning & Tweaking 0 07-08-05 09:19 PM
