Old 12-07-07, 02:25 PM   #1
ejohnh
Default speedo sender cable mudguard clip on curvy
Haynes said you had to remove front wheel in order to push the centre pin up thru the clip in order to get the clip off the front mudguard so that it (mudguard ) could be taken from the bike. I just undid the 4 bolts holding the mudguard on and raised it. Then used an electrical screwdriver with the tip bent at a right angle to push the pin out - worked a treat. Unlike the damn sikaflex 291 stuff which stuck like hell to the mudguard but just peeled off the pyramid extenda fenda.
What was that special grease to smear round the front spark plug cap to weather seal it? I think I'll forget the extenda
And meths is a good cleaner for sikaflex.
Old 12-07-07, 02:41 PM   #2
Stu
Trinity
Stu's Avatar
Default Re: speedo sender cable mudguard clip on curvy
Originally Posted by northwind
The grease you need is part number RE90X, Maplins website shows an aerosol but it's a tube.
Old 12-07-07, 03:38 PM   #3
ejohnh
Originally Posted by Stu View Post
Thanks Stu.
Is there any specific reason why the sensor cable is clipped to the mudguard. Can it just be clipped to the LH brake hose, like it is to the RH hose?
Old 12-07-07, 03:46 PM   #4
Stu
Trinity
Stu's Avatar
Originally Posted by ejohnh View Post
Thanks Stu.
The only reason it's clipped to the mudguard is to stop it fouling the wheel. so if you can achieve that any other way, go right ahead
Speedo sensor and cable Warthog Stuff Wanted 1 04-05-08 10:02 PM
Speedo Sender mattglavin Stuff Wanted 2 20-01-08 01:45 PM
Help! Speedo cable replacement brodie Bikes - Talk & Issues 3 12-02-07 11:11 AM
SV650 K3 speedo cable Khewett Stuff Wanted 0 01-05-06 07:24 PM
Is my speedo cable broken ? fizzwheel SV Talk, Tuning & Tweaking 14 30-11-05 10:30 AM
