#141 |
It happens...
It's easy, start with a perfectly good motorcycle, then make a complete c*nt of it... job bobbed.
#142 |
Lol he makes horse trailers and things like that out of wood and metal. He has made a few trikes for people to out of the big engined kwaks not sure of the name
#143 |
I had some running issues with the RGV recently. It lost all power on the way back from its MOT last week and conked out at the side of the road. The power loss occurred mid-overtake, which was nice.
![]() It started up again after a few kicks but problems persisted the rest of the way home. At sub 7k revs it was fine, but after a minute or two in the power band above that it started to stumble and lose power. I'd already had the expansion chambers off and checked the pistons and powervalves so I was happy that all the expensive bits were still in good order. This felt more like a fuel issue than anything else. Before doing too much of a tear down I decided to have a look at the fuel tap as it had suddenly become very stiff. On what was a pretty thorough rebuild the fuel tap was probably the only thing I hadn't removed - no need really (I thought). ![]() This was what I found when I removed it. ![]() The wee net filter is missing off the reserve outlet, so when I went on to reserve for a few miles a while back, it drew all the crap straight out the bottom of the tank. The filter wasn't in the tank so someone has decided it was OK to refit like that. The instruction to never, ever use reserve has then been lost in time. The tap itself was totally bunged up solid and the fuel lines were full of debris. There's a couple of wee filters that sit in the carbs. They looked like this. ![]() I pulled a pretty solid plug out of that filter. At least it stopped all that stuff going through the carbs but it wouldn't have been doing much for efficient fuel flow ![]() |
#144 |
Its always the bit you didn't check doh, least it shouldn't be an expensive fix
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
#145 |
How does the inside of the tank look as that debris has come from somewhere?
#146 |
Could have been a hopeless strip down!
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
#147 |
#148 |
Excluding the twig could the paint chips be some sort of tank liner?
#149 |
Doesn't look like there's anything like that.
#150 |
Strange, wonder what that stuff is then?
azonic evo II mountain bike (well its a bike so stuck it hear) | barwel1992 | For Sale - Other Bikes and General biking items | 1 | 18-05-11 09:06 AM |
sv650 for sale, great bike, watch a video of the bike here.. | ianlangerz | For Sale - SV's and SV related items | 0 | 15-02-11 05:39 PM |
Swap: 1999 SV 650 road bike, track biased mods. Minitwin bike? | Gazdaman | For Sale - SV's and SV related items | 2 | 06-08-10 08:28 AM |
First bike - Looking at a 650S. Right bike for me? Decision possibly today. | earthtodan | SV Talk, Tuning & Tweaking | 10 | 14-05-07 12:08 PM |
Sharman Multicom Bike to Bike radios, complete, NOW SOLD | jakeblues68 | For Sale - SV's and SV related items | 4 | 24-04-06 09:35 PM |
