Old 11-10-09, 09:53 PM   #11
Holdup
Default Re: Brake Pad life
Originally Posted by steveg View Post
Still on original front brake pads @ 42k miles , look good for 50k
Cheers Steveg
Do you drop and anchor to stop you! i thought most pads lasted like 8k miles.
Old 11-10-09, 11:27 PM   #12
squirrel_hunter
squirrel_hunter's Avatar
I replaced the front pads of my first SV at somewhere around the 70,000 mile mark. I was the second owner from new but doubt very much that they were replaced before I had the bike.
As for the rear, never needed to. I don't use the rear brake.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 12-10-09, 12:42 AM   #13
ixlr8
Still original rear pads at 145,000 km but 4th set of fronts. I have been using hard pads but having to replace front rotors at 120,000km was the penalty. Probably better braking and value to use softer pads in retrospect. BTW, most of those kms were urban couriering. I mostly use the rear for settling the bike and trail-braking.
ixlr8 is offline   Reply With Quote
Old 12-10-09, 05:34 AM   #14
you dont need brakes on an sv just pop her in 2nd and let the clutch out
ive never had to change pads on any bike i own? maybe i dont ride enuf.
Old 07-08-10, 03:47 PM   #15
TazDaz
At the 10k or so mark and the fronts still have loads of meat left yet the rear is almost worn.
I don't even use the rear other than for slow manoeuvres...puzzled.
Old 07-08-10, 04:48 PM   #16
Rocket
OK so my figures are for my 03 1000 but the factory Tokico HH pads lasted 45,000 miles on the rear and 22,000 on the front. After that I used EBC organic pads which are doing 22,000 miles front and rear. I'm just about to put another set of front and rear pads in at 66,000 miles.
Old 07-08-10, 05:05 PM   #17
Jordy
At 13k I don't think mine have ever been changed, no receipts to say so anyway... I have quite a bit left but I do get some brake squeel at slow speeds. Tried using brake cleaner on the discs but that didn't work.
Is it recommended to change the discs as well as the pads, like on cars?
Old 07-08-10, 05:21 PM   #18
Holdup
If you change the discs its recommended you change the pads at the same time, if your pads are worn you just replace pads
Old 07-08-10, 05:25 PM   #19
Jordy
Thank you Holdup.
Old 09-08-10, 02:35 PM   #20
chirpy999
Hi, nearly 13000 on my K5 pointy, I think theyll last another 2000 miles before front or back need replacing.
chirpy999 is offline   Reply With Quote
Brake pad life? metalhead19 SV Talk, Tuning & Tweaking 20 02-03-10 01:15 PM
Rear Brake Pad Life Sholay SV Talk, Tuning & Tweaking 20 09-08-05 12:56 PM
Life of rear brake pads pedrosis SV Talk, Tuning & Tweaking 8 20-06-05 10:33 PM
Life of a brake disc BaggaZee SV Talk, Tuning & Tweaking 3 13-04-05 12:12 PM
brake pad life? Itching 2 go SV Talk, Tuning & Tweaking 19 25-06-04 10:39 PM
