Old 02-08-11, 04:50 PM   #11
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: Making garage habitable
When can u start yc? How do I take the asbestos stuff away? Is that Only dangerous when it turns to dust? Guessing that'll be a contracted job?
you will get less jail time for murder
but if you want to risk it, its safe unless it breaks, then run
05 DRZ400E
RIP hovis
Old 02-08-11, 05:11 PM   #12
squirrel_hunter
squirrel_hunter's Avatar
Are you gonna brick up the door?
If not dont waste your money on insulating the walls cos it will be wasted.
This is something that I've been thinking about. Garage doors being just a thin bit of metal doesn't do much for insulation. What would you recommend to enable the garage to be habitable in winter whist still having a working door?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 02-08-11, 05:13 PM   #13
Our garage has one of them rolling electric doors, it's probably 2" of insulation but you can never seal up completely around, that keeps the place above freezing though it is part of the house so probably gets some waste heat through the walls.
Old 02-08-11, 05:24 PM   #14
Councils down this way will let you dispose of asbestos sheeting free of charge, you call them and they send you a certificate and the place to take it.
You soak the boards with water and keep them wet, get heavy plastic clear bags, while wearing a disposable suit and mask, put all the sheeting into the bags and tape up the bags so they are sealed.
Take them to the place where council have told you to go and they will have a special skip away from the rest which is normally locked, dump in there, job done.
Finally, bin mask and suit.
Old 02-08-11, 05:25 PM   #15
Paul the 6th
Paul the 6th's Avatar
Paul, i convert garages, amongst other things for a living, depends on your budget, do you wanna leave it as a converted room? do you wanna be able to sell it as a converted room? etc etc.
Dont DIY the roof mate it wont last and will be false economy, by all means frame and board it yourself, but get the felt torched on by a roofer as it will last.
What the building control want these days is foiled backed cellotex of at least 100mm then plasterboarded over the top of them, 150mm of celotex or similar in the roof.
The floor will need some insulation as well, which can be done by putting 60mm celotex on the floor tight, then lay 22mm flooring grade chipboard over it with glue joints so this creates a floating floor which will work well.
I can advise how to do pretty much everything you need, i can give you my moby if you get stuck as long as i dont get calls at 3am
Smooth Philadelphia, cheers buddy I might just take you up on that tbh I should probably set a budget and then see how far that'll take us rather than envisaging a fully decorated cream walled laminated flooring room with halogen down-lighters a good friend mentioned he knows a guy who replaced all the felt on his roof for £500 - and his garage is around 6-8ft longer than mine = is that a fairly realistic price? For good quality torched roofing?
In terms of spec:
  • keeping the big garage door since I still want to be able to get a trackbike in there later on - and also ideal for getting stock in and out easily (plus would be nice to have the garage door open on hot days)
  • Ideally laminate or lino flooring, hardwearing, easier to keep clean
  • Insulation - the door on there is a motorised roller door with a big 6-8" gap above it, so no point insulating
  • Do the building control regs about insulation only apply if you're making the garage into a proper living space? I guess I was a bit over zealous with the title for making the garage 'habitable' - just want to make it dry, clean, leak proof, spider free and a nice place to work
  • Would there be any issues with damp getting in? if it's not fully sealed and insulated?
don't forget to visit your local building seconds/recycling yard, often overlooked and you can find some good cheap materials that only need a bit of a tart up. I built a shed down the side of house for my dad that's got all his vinyl cutters and printers and the garage mapped out for the engraving and manual machines. Did what YC said for the roof with some inch birch ply, joining the boards with drainpipe sealant, then felted. Put a second hand velux in the roof for daytime light. been up nearly three years now and all is still pukka, no leaks and best of all it cost feck all as i salvaged the boards off of a job i ripped out
and utilise under bench space with compressors ect
Nice one gavinski - I'll have a look around to find out if there's anyway where near here.. we got a recycling centre up the road but its always full of old washing machines & garden waste.
fair play, but these days copyright theft usually carries greater sentences than murder as well nah in all seriousness I'll find a local firm to do the job safely and dispose of it in the correct manner..
Old 02-08-11, 05:27 PM   #16
You probably won't get it to be that damp and spider free with a 6" gap over the door.
Old 02-08-11, 05:32 PM   #17
Paul the 6th
I'm expecting the odd spider but as it stands there's hundreds in there because of a breeze vent built into the brick and gaps under the corrugated roofing (plus the Ivy is starting to grow in)..
It's not so bad for damp at the moment but come to think of it, even a little bit of damp would quickly knacker vinyl stock and make box fresh clothing stinky and mouldy over time
What's the options for still being able get a bike in there but with a reduced-down door?
Old 02-08-11, 05:33 PM   #18
Paul, single skin walls are prone to damp tbh as you get moisture coming through and theres no thermal break.
Don't ever dab plasterboard straight on the walls as it will go mouldy in no time.
Average price down here for torch-on felt is around £30-£35 a square metre, I'd make sure they have at least two layers, one undercoat, one top layer and it's torched right into the wall chase and pointed up.
Old 02-08-11, 06:02 PM   #19
tbh I should probably set a budget and then see how far that'll take us rather than envisaging a fully decorated cream walled laminated flooring room with halogen down-lighters ..
Well its what was in my parents garage by the time my bro finished with it, apart from his wasn't cream it was some nad orange colour. Can't remember what he did with the garage door, but it ain't on the inside....but its sure as hell there on the outside
Old 02-08-11, 06:11 PM   #20
A friend of mine did that, at some point some scroats had basically demolished the door to get in. Would have loved to have seen their faces when they had destroyed the door only to be faced with a brick wall!
making your own guitar Wideboy Idle Banter 31 25-04-10 08:29 PM
What's the minimum size for a garage to be a garage? the white rabbit Idle Banter 3 20-12-09 08:39 PM
COD MW3 in the making suzsv650 Idle Banter 6 16-11-09 08:56 PM
Making a web page metalmonkey Idle Banter 5 23-02-08 10:42 PM
Making you own gel seat? muzikill SV Talk, Tuning & Tweaking 6 13-01-06 04:42 PM
