Old 08-09-11, 06:20 PM   #11
Default Re: Does my bike need a valve service?
if you wait till january its usually cheaper as a lot of dealers half their hourly rate. an added bonus is that the bike will cool down a lot quicker outside so your bike is with them for less time.
Old 08-09-11, 08:25 PM   #12
Stonesie
I don't think it quite works like that, they don't usually check the engine with a thermometer before checking the clearances. An overnight stay before starting the service is the usual way of making sure it's sufficiantly cool.
Old 08-09-11, 08:50 PM   #13
ian505050
£120 for Valve clearance check/service at Jordans in Leeds for the point sv.
Old 08-09-11, 08:52 PM   #14
ian505050
dont talk ****, its not cheaper because bikes cool down quicker lol
Old 09-09-11, 03:11 AM   #15
beabert
He never said it was!
Old 09-09-11, 09:06 AM   #16
a bike does not have to be stone cold to check the valve clearances, it just has to be cold enough. colder weather will cool the bike down quicker so you don't have to leave the bike with them overnight.
i think you have misread my statement. what i was saying is in january the hourly workshop rates of the dealers usually go down. because of the cold ambient temperatures you don't have to give them the bike overnight.
thank you. someone with a brain
Old 09-09-11, 12:04 PM   #17
AndyBrad
bike has to be stone cold surely?
Old 09-09-11, 12:08 PM   #18
dyzio
dyzio's Avatar
Why is that?
To measure the gaps properly?
Old 09-09-11, 12:53 PM   #19
define stone cold...
stone cold in Australia is completely different to the UK due to higher ambient temperatures. same goes for summer verses winter in the UK. all you are looking for is a temperature cold enough to make sure that you don't warp any parts that you remove so as long as the parts stay a uniform temp while you are dong the work things should be ok. i'm not saying that you should do the work on a hot bike or even a warm bike but cold enough to ensure that the parts wont have a huge difference in temperature when you remove/assemble.
same goes for the gap spec of the shims. a bike adjusted in the hight of summer might be out of spec in the deepest of winter but i very much doubt it. when it comes to valve gaps then i'm afraid near enough is good enough as long as its not to tight or loose.
Old 09-09-11, 01:25 PM   #20
AndyBrad
its all relitive. basically you need it cold so that you can get an accurate measurement of your clearances. they give you a tolerance and it relects on it in relation to the rest of the mating components (i.e. respectivly everyhting will be at an increased ambient temp in oz as opposed to here) it MUST be cold to get an accurate measurement so you dont have residule heat in the head for example giving you an increased gap that then closes up when its cold
Valve service SUPERSTARDJ01 SV Talk, Tuning & Tweaking 3 05-08-11 11:52 PM
Cheap service and valve clearence check Double D SV Ecosse 11 24-04-11 09:10 PM
Cost for 15k (valve?) Curvy Service? Scythe92 SV Talk, Tuning & Tweaking 6 24-02-11 04:09 PM
Valve clearance service - pricing and where? daveb SV Talk, Tuning & Tweaking 15 14-05-10 05:01 PM
15k service - valve clearance The Mass SV Talk, Tuning & Tweaking 21 18-08-05 09:41 AM
