Old 05-08-11, 01:44 PM   #1
SUPERSTARDJ01
Default Valve service
Hi,
how hard is to do a valve service? I have a triple, the tools and will get a haynes manual.
Any tips?
Old 05-08-11, 07:27 PM   #2
Fade
Default Re: Valve service
Which triple?
Old 05-08-11, 10:14 PM   #3
SUPERSTARDJ01
Street r
Old 05-08-11, 11:52 PM   #4
Fade
It's not too bad, just need to be methodical and check you really have undone/removed everything!
Tank off, then airbox, then tbs, coils and plugs take the crank cover off so you can turn the crank over and bobs you uncle.
That is if none need changing, even then just whip the cam tensioner out then the ladder and cams. The crank has a spot to line up at tdc and make sure the cams are put back correct. The tensioner is a bit of a pain to reset but you just need to put it on a clean surface and use your palm to compress it and then some fingernails to get the locking clip in place. Once all back in turn the engine over the correct way and the tensioner should pop out, remember the correct way is clockwise as you are looking at the end of the crank cover.
Cheap service and valve clearence check Double D SV Ecosse 11 24-04-11 09:10 PM
Cost for 15k (valve?) Curvy Service? Scythe92 SV Talk, Tuning & Tweaking 6 24-02-11 04:09 PM
Valve clearance service - pricing and where? daveb SV Talk, Tuning & Tweaking 15 14-05-10 05:01 PM
Recommend me a garage in the Teesside area for 15k service (inc valve clearances). Tim in Belgium Pennine Massive 8 27-07-07 11:18 AM
15k service - valve clearance The Mass SV Talk, Tuning & Tweaking 21 18-08-05 09:41 AM
