#11 |
What's faulty? You've got something cheap, light and stiff enough. More stiffness is not always good
#12 |
#13 |
Eh?
#14 |
#15 |
#16 |
#17 |
I was looking at a pointy sub frame on e bay .might be a cut n shut , November when its sorn.
Raisin cookies that look like chocolate chip cookies are the reason I have trust issues. |
#18 |
its definately cut and shut, I bought a later ally one by mistake as steel would have been easier to splice the curvy onto it, but hopefully one of the welders at work might be able to do something if I ask nicely
#19 | |
And Mr. Squid, please, we've talked about this, there is another bike first in the line... |
#20 | |
![]() However, I do feel that with a bit of polish it can be made to look sweet, if funky shapes are your thing, why not go down the route of deep bracing? The modification should be simple enough and will add a degree of character to the otherwise clean and simple swing arm. Once finished and highly polished, I am pretty sure that it would look the dogs danglies. ![]() If you want to go completely wild, you could go for bracing at both top and bottom, but this would worry me due to my hugger getting in the way or it hitting the sub frame if not done low enough. ![]() By doing this, one could have the bracing join a centre section that could also shield the shock from road spray, however I strongly suspect that the only benefit of such a modification would be cosmetic. ![]() Now if only I knew a local welder who can do aluminium sexiness and not ruin an otherwise fine swing arm. ![]() |
Swinging arm bearing gap | Mannerheim | SV Talk, Tuning & Tweaking | 13 | 09-12-09 08:54 AM |
Chain adjustment markers on swinging arm | Cairo | SV Talk, Tuning & Tweaking | 5 | 17-09-09 03:51 PM |
swinging arm suspension linkage bearings | 21QUEST | SV Talk, Tuning & Tweaking | 13 | 05-08-08 01:40 PM |
scratched the black paint on my swinging arm | ged | SV Talk, Tuning & Tweaking | 2 | 14-01-07 09:04 PM |
Swinging arm pivot greasing | curium | SV Talk, Tuning & Tweaking | 3 | 03-04-05 04:40 PM |
