#11 | |
As tempting as this sounds, I think that if I go down this path, then I will probably wire in a manual switch as temporary repair until I can get a new thermoswitch from my brother in law. |
#12 |
How hot did it get Jayne.
From memory I think mine had to get to about 105 to kick in and then dropped back out about 100
Not Grumpy, opinionated. |
#13 | |
#14 |
#15 |
105 is about right, at 115 or so unpleasant things occur.
They are cheap. PM davepreston he has a spare knackered rad with switch on it.
#16 |
after 9 months of having the bike i discovered that my fan switch was toast too. I discovered it in standstill motorway traffic on the way to Dover. Bike got to a very scary 118 at one point and came to the point where i had to filter at a rate of knots to get it cool or pull over and shut off.
Got v. interesting in 35 degree monaco heat too ![]() I hear that there's an internal shutoff temp around 120ish? Or by shutoff do i mean eject its own innards and shutoff forever? |
#17 |
Too hot and it will boil
#18 |
Depending on how accurate your temperature gauge is--------but I think that a 50/50 mix has a boiling temp of round about 107C or 108C
#19 |
Right then, it is now bodged with in an inch of it's life. Dash mounted switch so I can manually turn it on when it starts to get hot. I have checked it and it all seems fine, but while I was at it, I did a cheeky oil and filter change too!
#20 |
Good stuff - I'm not sure the words 'dispatch rider' and 'chic' can ever fit in the same sentence though.
MOT Failed! | Dunn-y | Bikes - Talk & Issues | 16 | 18-05-11 12:49 PM |
Failed CBT - Twice | Littlepeahead | Idle Banter | 46 | 12-03-10 07:41 PM |
failed again | shiver85 | Bikes - Talk & Issues | 5 | 17-05-08 12:04 PM |
TRE mod failed on 07 | vegacr250 | SV Talk, Tuning & Tweaking | 21 | 09-07-07 10:28 PM |
Failed ignition switch - again | seedy100 | SV Talk, Tuning & Tweaking | 7 | 05-03-07 08:47 PM |
