#11 |
Cheers for the positive comments guys, I thought this would interest some of you.
Ruffy, if you do find anything let me know as it might be on the list. |
#12 |
While it was sitting in my garage for months on end the more I looked at it the more I wanted to ride it. So I spent some time tracking down parts. It took me 4 months to get a set of plastics. Traveled to London one night to pick them up, a full set, no real damage but in need of paint. I even bought two "rust free" tanks on eBay, but more on that later.
Occasionally I would move it around a bit to see what I could spot on it that was in need. Basically the obvious missing fairings needed sorting. The handlebars, leavers and switch gear had crash damage, plus there was a nice dent in the tank. The wiring was a mess the more I looked at it. The throttle was stuck as was the fuel tap and the chain would flap in the wind. Forks were pitted so I presume the seals are gone, and the brakes need a strip and rebuild. Other than that it would be consumables. There were two keys for the bike, the seat and ignition were on one, the tank on the other. Putting the key in the ignition was much like throwing a pasty up Park Street so for that reason and the fact I feel two keys would let the bike down a replacement lockset went on the list. The list was getting longer. Anyway at some point and I don't know when exactly I made the decision to go the full distance on it and fully strip it down to powdercoat the frame and build it back up from there. So the strip down begins. ![]() Tank off reviled the dirt on the inside of the frame and on the engine, plus the overall condition of the bike. It also showed how small the bike is. the amount of space under there is amazing. ![]() Next it was the air box. The screws holding the lid on did their best to delay me and at one point thought that I wouldn't get them to cooperate. But in the end they relented and I was presented with a very clean air filter. ![]() That promptly disintegrated as soon as I touched it... Is this an omen? |
#13 |
No, it's completely and utterly normal, thus not signifying anything bad, (or, I suppose, good), about your 'new' bike.
#14 |
Awesomeness
![]() I remember your interest in the cost of 2 stroke engine rebuild kits. All now becomes clear. ![]() Have fun. |
#15 |
Well it is worrying when the first thing you touch falls apart in you hands. But having cleared off the filer (new one going on the list) the inside of the air box looks quite clean.
![]() Can't say the rest of the bike is that clean once the box was removed. It actually took me 5 minutes to locate the screws for the air box clips under that amount of dirt and grime. ![]() The plan now is to drop the engine out. So first remove the exhausts. Fearing the worse from my experience with SV front down pipes I was expecting the header mounting bolts to be seized or worse. Imagine my surprise when they came off so easily. I think it might have something to do with the tar that was coating them. I suspect the exhaust gaskets may have been leaking. ![]() However the rear mounting bolt did complain and that had to be cut off. The exhaust is only actually held on with 3 bolts 2 in the front 1 in the rear. And the rear mount is also a rubber damper. I expect that they didn't look like mine do now back in 1987. A pair are also now on the list. ![]() Once the exhausts were off I could get a better look at them. They are standard exhausts. But I think they have had a hard time. The cans have been wrapped in metal that has been tack welded on. I presume this was to hide crash damage. As for the header section, it has been repaired at some point. ![]() Now as I am aiming for a standard machine I need to think about what to do with these pipes. If they are still available from Yamaha I think they might be a little on the expensive side. As are some aftermarket pipes I've seen, though they will need rejeting no doubt. But these pipes might also be expensive to repair. Alas I have some time to decide what to do with them as they are near the last things that need putting back on the bike, but if anyone has any suggestions feel free. |
#16 |
The exhaust gaskets on LC/PV always leak, that's just how it is - the sun comes up in the east, sets in the west and LC exhausts are always dribbling 2T down the front of the motor. Get used to it.
These are the things set in stone by - insert your deity of choice here - eternal verities that are reassuringly certain. The pipes are rubber mounted as the motor is on fairly sloppy rubber mounts and the exhausts move a surprising amount, sloppy is good here - too securely fitted and the pipes can crack. Odd repair to the front pipes, being a stinkwheel the pipes neverevereverever rot through, (lots of lovely oil in there, worse when the pump is set wrong - which is common), so that's a bit of a mystery, crash damage perhaps?
#17 | |
![]() Chris
10 GSX650F 95 BMW Funduro 89 FZR250R (x2) 92 RG80 (x2!) 89 AR125 - 89 RG125 75 CB200 |
#18 | ||
As for the repair, possible crash damage. I know its been down the road but its an odd place to have it. But thinking about it I don't remember seeing anything on the other side as you would think if its our road salt and rust I would expect to see something on the other side to match. Strange... Threadlock is now on the list, thanks. |
#19 |
#20 | |
Garage can't find paint colour for the SV | Fifteen15 | SV Talk, Tuning & Tweaking | 21 | 09-09-11 11:04 PM |
It's amazing what you find in your garage | dirtydog | Photos | 20 | 07-05-10 08:52 AM |
Classic Bike find in garage | kwak zzr | Bikes - Talk & Issues | 13 | 13-03-09 06:42 PM |
Where can I find clutch housing bolts? - Cant find any | mikeSV | SV Talk, Tuning & Tweaking | 2 | 24-03-08 12:30 PM |
Where can I find a good garage in London | fred | SV Talk, Tuning & Tweaking | 4 | 20-01-06 03:34 PM |
