#11 |
Looks like a useful bag.
When I fitted the vacuum line I popped the little rubber boot off the throttle body to make the connection, but found the boot full of fuel. In hoping this is because it had been running a but rich in a cold start with an almost flat battery when I took the bike out of the garage minutes before. |
#12 |
I have a Tutoro manual on my K8, the resivour is cable tied to the chain guard mount and a small pipe comes down and through the threaded hole where the paddock stand bobbins would fit and goes on to the sprocket just above the chain,this works ok
problems are the resivour is small and needs regular topping up and you have to remember to turn it off and on (about 1 1/4 turns for dry summer use), but they cost £20 what ever you do dont waste yuor money on a twin feed if your sprocket is wider on the outside than the centre as you will have to mount it so close to the chain that the chain will grab it and chew it to pieces |
Scottoiler with fitting kit etc | skithepowder | Stuff Wanted | 2 | 27-02-11 07:08 PM |
Scottoiler fitting. | Nick_69 | SV Talk, Tuning & Tweaking | 51 | 13-02-10 11:48 AM |
Scottoiler Fitting K9 | TheRamJam | SV Talk, Tuning & Tweaking | 14 | 09-06-09 05:11 PM |
Fitting Scottoiler | plowsie | SV Talk, Tuning & Tweaking | 32 | 12-06-07 06:42 PM |
Fitting a Scottoiler. | Grinch | SV Talk, Tuning & Tweaking | 110 | 24-01-07 09:21 PM |
