Old 23-04-17, 08:03 PM   #11
SheepShagger
Default Re: New member - Cafe Racer (ish) project.
Originally Posted by Tannoy964 View Post
It's not the standard one, it's another ebay special (£45 delivered). The reason i didn't keep the standard one is that on the faired SV (MKI anyway) the fairing grommet mounts are welded to the sides and I wanted clean lines. I didn't want to hack them off as I'm keeping all the original parts...so a new one was needed. It very nearly fitted as well!!! but unfortunately the bottom mount was off so I made and adaptor plate. You really can tell unless you go looking. The cover frame was a made at work, the honeycomb mesh was supplied again...you've guessed it..by ebay! Oh and I moved the horn...looks better out of the way and can only help with cooling...not that it's ever been a problem.
I tried one of those ebay jobs on my build an encountered the same issue, i sent mine back though, had a mare with the sellet too. I went for one of the Delkevik units in the end.
Sent from my SM-G935F using Tapatalk
SheepShagger is offline   Reply With Quote
Old 23-04-17, 08:23 PM   #12
Tannoy964
Junior Member
Thanks. The exhaust is made by Scorpion - the high level oval 400mm version with removable baffle . It comes highly polished (with sticker) but as I wanted the brushed finish the sticker had to come off. The springs on the link pipe were added as I liked the look. Getting the seat and exhaust to align was a bit of a pain. I added rose joints to the subframe to lift the back end a little. To be fair the standard set up is not too far off. Hopefully if i've done this right there should be the details of the exhaust below...
Tannoy964 is offline   Reply With Quote
Old 23-04-17, 08:33 PM   #13
Tannoy964
Junior Member
Sorry guys...replied to the wrong person...doohhhh!!
I agree the Delkevic is a far better rad...the rad was the last item to get replaced and funds were running low.
Old 23-04-17, 08:39 PM   #14
SheepShagger
Sorry guys...relied to the wrong person...doohhhh!!
I agree the Delkevik is far better rad...the rad was the last item to get replaced and funds were running low.
I know that feeling, i've blown about 6k on my build, should have just gone simple like you.
Old 23-04-17, 08:40 PM   #15
R1ffR4ff
R1ffR4ff's Avatar
Great looking job.Dunno if it bothers you but,"They" are very keen on the North bank of the Humber on none standard number plates
What are they like around your way?
Old 23-04-17, 08:48 PM   #16
Tannoy964
Junior Member
I've not had any bother so far, touch wood.
But if I get pulled up for it, so be it, the larger one will go back on.
Old 23-04-17, 08:52 PM   #17
R1ffR4ff
R1ffR4ff's Avatar
It started here after they got the ANPR in the cars and there's even a couple of special cameras here in Hull with ANPR.
I can't argue with it as I don't want uninsured T*ats on the road etc but I can't see the harm in a custom plate so long as their gear can read it
Old 23-04-17, 09:08 PM   #18
squirrel_hunter
squirrel_hunter's Avatar
Thanks for the info on the rad.
I also like what you've done routing the rear brake line along the torque arm, keeps it very clean, a nice touch.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 24-04-17, 10:07 PM   #19
DomP
Where did you get the indicators from? Want rid of my pointies lollipops
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired
White 2011 YZF R125 sold
DomP is offline   Reply With Quote
Old 25-04-17, 06:57 AM   #20
svbmx
svbmx's Avatar
LIKE Nothing over the top, very nice.
Blue 99 SV650s... Naked SV/GSXR/Ducati Hybrid! Build Thread... HERE!
svbmx is offline   Reply With Quote
Cafe racer Craigieboy636 SV Talk, Tuning & Tweaking 6 26-08-15 08:36 AM
Curvy Engine for Cafe Racer project. Bunkle Stuff Wanted 1 08-11-14 11:25 PM
Cafe Racer maviczap Idle Banter 7 16-12-11 10:24 AM
Cafe Racer - I like Tim in Belgium Idle Banter 6 22-06-10 08:44 PM
Cafe Racer Steve H Bikes - Talk & Issues 11 21-06-07 11:32 PM
