Old 27-08-19, 10:48 PM   #11
squirrel_hunter
squirrel_hunter's Avatar
Default Re: I'm a numpty
I removed the OE adjuster & heard a twang
Yep, as soon as I read that I knew what you'd done. Because I've done it my self. Didn't have the timing on the correct mark when I removed the CCT and I knew something was wrong by the sound. Thankfully I didn't start it as the engine was on the bench but it resulted in spending a hour or so resetting the timing and double checking everything again. Lesson learned.
But that exhaust hack is horrific!
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 28-08-19, 12:39 PM   #12
timwilky
timwilky's Avatar
Not with SV engines, but I have experienced that valve piston interface a couple of times as a result of timing chain/belt/key failures.
I have inspected pistons and OK'd them and subsequently had them fall apart a week or two later. So lucky it survived for you.
Not Grumpy, opinionated.
Numpty newbie Tdi90 Idle Banter 13 03-09-15 05:50 PM
Numpty -Ralph- Idle Banter 11 22-10-10 10:41 AM
Numpty moment... Baph Idle Banter 7 21-02-09 08:16 PM
What A Numpty!! Ollie Pennine Massive 10 21-02-07 07:04 PM
Which numpty? mynameis Bikes - Talk & Issues 22 08-06-06 08:55 PM
