#11 |
I've had really good results with a hydrochloric acid based wheel cleaner - it really dissolves the gum and white crud well. Problem is it will also eat away at the alloy if left too long, so I use it fairly weak and make sure I rinse everything really thoroughly after using the stuff. I don't leave the alloy bits in for more than a minute or so at a time, but the brass bits can be soaked for a while longer.
I'm told that toilet duck ( also acid based) works well, but haven't tried this myself. When I run out of this stuff I'm going to try brick cleaning acid from B&Q 'cos this is also based on hydrochloric acid. Don't forget to wear goggles. |
#12 |
Thanks guys. So it appears there is no hard and fast solution. Plenty of ideas to try out though.
Carb Cleaning | mattglavin | SV Talk, Tuning & Tweaking | 4 | 29-10-07 12:29 PM |
What is a High Flashpoint Solvent | 2mths | SV Talk, Tuning & Tweaking | 23 | 22-06-07 08:24 AM |
where to buy acetone (or other fiberglass resin solvent/cleaner)? | weazelz | SV Talk, Tuning & Tweaking | 6 | 08-05-07 09:09 AM |
Arrrgggggggggghhhhhhhh - Soaking Wet Hands | I'm_a_Newbie | Bikes - Talk & Issues | 18 | 23-10-06 08:54 PM |
what solvent and sealant? | lukemillar | SV Talk, Tuning & Tweaking | 7 | 11-09-06 04:44 PM |
