#21 | |
Mad. To clarify - was the one that broke the one that you used on the wrong link?
If an SV650 has a flat tyre in the forest and no-one is there to blow it up, how long will it be 'til someone posts that the reg/rec is duff and the world will end unless a CBR unit is fitted? A little bit of knowledge = a dangerous thing. "a deathless anthem of nuclear-strength romantic angst" Last edited by Sid Squid; 28-04-10 at 03:10 PM. |
#22 | |
I can't think of anything. Oh no wait, how about we didn't know about the different types at the time. If I'm honest I'm still unclear. What tool is required for which one and how can you ensure that the correct chain/ tool combination when you order? |
#23 | |
Large Member
[QUOTE=squirrel_hunter;2254693]
QUOTE] Squirrell you great daft banana what you talking about? The tool, as linked to in the first post of the thread, did get borrowed by one of Squirrells collegues and returned with a new pin in it as he snapped it. I can only presume he was trying to insert a new link in the chain that holds the anchor to the HMS Big Bloody Ship The only one we broke was the Motrax one which bent doing the chain on the Thundercat, it was the right link because the pins in the link had a tiny little dimple in them indicating where to squash them. Oh and there were not attached to owt when we started ![]()
How to amuze an idiot: Look right-> <-Look Left |
#24 |
I though our Squid was on about the Motrax one? If not ignore everything I just said.
As for the pin being broken on that riveter (the good one), I have a sneaking suspicion that the lended didn't grind the heads of first. |
#25 |
You sir are a gentleman - I greatly admire your honesty
#26 | |
I ended up having to pay a shop to rivet it for me! If you look on chain manufacturers websites, they don't bother telling you which rivet they use. Even websites like B&C express use generic pictures which aren't indicative of the actual link type. From now on I'd just stick with one brand! |
#27 |
Just checked back to find more amusing posts on this thread, thanks guys.
So the chain tool is pretty good, very easy to use and seems very substantial. Had no problems breaking the new chain once I had ground the heads off the soft rivets. ...but, I got carried away and did the old rusty chain too, without loosening the front sprocket first :/ Now I have a free rotating front sprocket and no chain and back brake to stop it from moving. At present my current plan is to fit the new chain on the old rusted front sprocket, loosen it using the new chain and back brake. I am slightly worried that the old rusted sprocket is going to damage my nice new chain. I've read that putting it in gear to undo the sprocket bolt can damage the transmission. Is this true? Any suggestions would be welcomed gratefully. Thanks Nath |
#28 | |
Just get a mate to really stand on the rear brake pedal and you'll get it off with a big breaker bar. |
#29 |
The clutch would slip before that happened. Every bike mechanic I know puts the bike in gear when removing the gearbox sprocket, you won't do any more damage to the gearbox than revving it to the redline and then changing gear would do.
#30 |
My DID chain rivetter is supposed to push the pins out without grinding, but I've always ground them anyway to give the tool an easier time. I've not had to buy a new pin for it yet.
Chain question. | Specialone | SV Talk, Tuning & Tweaking | 21 | 22-01-10 07:28 PM |
chain question | Wideboy | Bikes - Talk & Issues | 36 | 21-02-09 12:31 PM |
chain splitting/riveting tool | cyphertheory | SV Talk, Tuning & Tweaking | 1 | 23-08-07 03:48 PM |
Chain riveting tool | falc | Guildford Massive | 36 | 05-01-06 04:31 PM |
chain riveting tool | curium | SV Talk, Tuning & Tweaking | 5 | 21-02-05 04:59 PM |
