Old 09-03-14, 06:23 PM   #21
Darkzy43
Default Re: Curvy engine fit Pointy?
See above, Used a bar, then tried the impact gun and then used a longer bar and snapped my flywheel puller Hight tensile bolt.
Old 09-03-14, 06:25 PM   #22
zadar
Some can be stubborn
If you snapped puller it is not tensile enough.
Old 09-03-14, 06:27 PM   #23
Darkzy43
I think it's where the crank overheated from the crash, after I was unconscious and the bike was running without oil filter or oil for 5~ minutes.
Not to worry. As long as the one on the engine i'll be buying soon comes off.
What's the reasoning for needing the new rotor/stator.
Old 09-03-14, 06:31 PM   #24
zadar
Rotor has ignition and fuel pick ups on pointy that are different than curvy. For same reason you need gear sensor.
Old 09-03-14, 06:32 PM   #25
Darkzy43
Ahh fair enough.
Old 09-03-14, 11:58 PM   #26
squirrel_hunter
squirrel_hunter's Avatar
Originally Posted by zadar View Post
Both. And you want to change gear selector sensor.
Thanks for the info. Might be handy for the future...
As for the problem of removing the rotor, I have had a problem with this myself. In the end I threw the motor away (the big end had gone on it anyway I just wanted a look at it). I did read something somewhere about heat and pressure and time to remove the rota, will try and dig it out.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 10-03-14, 12:01 AM   #27
Darkzy43
Time to get the Oxy-Acetylene tanks out then!
Old 10-03-14, 12:16 AM   #28
zadar
Just be careful with heat if you plan to save rotor. Don't overheat it or magnets can fall out. They are epoxied to rotor and to much heat will melt epoxy.
You can try putting some torque on the puller and tap rotor with hammer, or tap on puller head. It is like impact but is easier on threads.
Old 10-03-14, 12:19 AM   #29
Darkzy43
I was thinking, if the crankshaft is kaput anyway.. can i not drill very carefully into the crankshaft to weaken it and hopefully contract it a bit?
Old 10-03-14, 12:22 AM   #30
zadar
No, don't even try. Try tapping like I mentioned and if still does not pop use some heat but only on very middle of it where it contacts crank.
Pointy engine in Curvy - how? splinter696 SV Talk, Tuning & Tweaking 15 05-06-12 07:05 AM
Curvy engine same as Pointy? SV..al SV Talk, Tuning & Tweaking 4 06-04-12 08:57 AM
pointy engine to curvy frame mart SV Talk, Tuning & Tweaking 6 11-03-09 04:13 AM
can a pointy engine go in curvy sottondan SV Talk, Tuning & Tweaking 2 05-07-08 08:42 AM
Curvy engine in a pointy rowdy SV Talk, Tuning & Tweaking 3 07-06-08 03:59 PM
