Old 22-03-18, 01:01 PM   #21
svbmx
svbmx's Avatar
Default Re: New project... 86 GSXR 1100
Little update. Welded and cleaned one side...
Got a bandit 1200 motor. Needs a good scrub but should clean up nicely.
And a lovely set of custom rearsets from http://grumpy1260suzukispares.co.uk
Blue 99 SV650s... Naked SV/GSXR/Ducati Hybrid! Build Thread... HERE!
svbmx is offline   Reply With Quote
Old 16-10-18, 12:00 PM   #22
svbmx
svbmx's Avatar
UPDATE... (It’s been awhile!)
I’ve cleaned the engine up abit (but not alot!) and have it in place so i can make the mounts.
The rear shock relocation is now complete, along with some additional bracing. Super happy with it.
I’ve had to have the sprocket carrier machined so the wheel can sit central.
I finished off the tank/tail shell and have also made the subframe. The 2 pieces are now connected via a hinge and supported by 2 mini gas struts. These will lift the shell from 45 degrees to vertical but are mainly in place just to keep the shell safely in its vertical position whilst access is required.
Im also playing around with ideas for holding down the front of the shell. Quite liking this style of latch either side, bit of a feature. Thoughts?
I’ve also made the fuel cell, well, almost... i ran out of gas! This has a channel for wiring and a flush fitting fuel cap. Once welded, Il be filling it with foam baffle cubes. The tank will hold approx. 13 litres.
Ideally i would have liked to make the shell from either carbon fibre or aluminium, and the subframe + fuel cell from aluminium too. But as i can only weld steel and wanting to do as much of the build myself, i opted for what i can weld. Perhaps once the build is complete il learn to weld aluminium and remake the parts.
Anyway, still lots to do but its definitely starting to take shape
Old 17-10-18, 06:09 AM   #23
Geodude
Geodude's Avatar
Nice work as usual, thanks for the update
Old 17-10-18, 10:34 AM   #24
looking good.
Old 17-10-18, 11:49 PM   #25
squirrel_hunter
squirrel_hunter's Avatar
Good progress.
The latches to hold the shell down are different, depends on the overall look that you are going for...
As for the tank or fuel cell, why fill it with foam and whats the detail here? What are you going to do to ensure that the tank is fuel tight? Also are you planning to treat the inside of the tank at all?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 18-10-18, 09:36 AM   #26
svbmx
svbmx's Avatar
Thanks all
Thanks. Once fully welded, I'll be treating the inside of the tank with some tank sealer. I might see if i can use the leak tester at work too. And the foam baffle cubes will prevent the fuel from sloshing about.
Old 18-10-18, 09:37 AM   #27
svbmx
svbmx's Avatar
These...
https://www.merlinmotorsport.co.uk/p...cube-tank-foam
Old 19-10-18, 11:45 PM   #28
squirrel_hunter
As you're making the tank yourself why not add some baffles into it as opposed to the foam? Also do you know how much foam is required and how long it lasts?
Old 11-12-18, 10:30 AM   #29
svbmx
svbmx's Avatar
Bit more done to the slabby.
Fuel tank done except the breather (waiting on some stainless pipe), engine mounts made, just need to radius the corners. Seat base ready for upholstery. Next the exhaust...
Old 11-12-18, 10:57 PM   #30
some very tidy work going on there
GSXR 750 SRAD '97 - Project Griff-SV For Sale - Other Bikes and General biking items 8 28-10-12 05:01 PM
GSXR 1100 L front end (almost) complete Owenski For Sale - Other Bikes and General biking items 0 15-10-10 10:05 PM
GSXR 1100 Front end on eBay Owenski For Sale - Other Bikes and General biking items 6 15-10-10 09:01 AM
wanted - gsxr 1100 whole or engine riktherider Idle Banter 4 22-12-08 07:33 PM
Beware chaps Plod has some new toys GSXR 1000 CBR 1100 amarko5 Pennine Massive 4 12-09-05 12:31 PM
