Old 20-05-10, 11:27 AM   #31
squirrel_hunter
squirrel_hunter's Avatar
Default Re: Fuelling problem - Babyblade.
Just had a thought (please no jokes). What bulbs are you running? Silly as it sounds but the standard ones are easily replaced with more powerful UK bulbs. The down side is the electrical system can't cope, I found this working on a NC29 a couple of years back. The only problem is I don't have a book of lies in front of me to tell you the standard bulb spec and the type they can be replaced for, but its something to consider...
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 20-05-10, 11:31 AM   #32
gruntygiggles
DaffyGingerBint
gruntygiggles's Avatar
Hmmm, I'll ask in a bit as I'm off to get the fork now. I'll also check out the book of lies (it's your book isn't it?) and see what that says. It's firing up no problem now but I'll still leave it on charge til we're hopefully ready to go later!
2012 Welsh TT
RIP Hovie baby
Old 20-05-10, 11:37 AM   #33
squirrel_hunter
What I meant was I don't have an electric copy in front of me. Good luck getting it all back together in time.
Old 20-05-10, 12:29 PM   #34
_Stretchie_
Large Member
_Stretchie_'s Avatar
Originally Posted by gruntygiggles View Post
I then have to (get Stretchie to) put it back on although I'd quite like to do it....with lots of his help.
Done, tonight my love, you will put the fork back in while I supervise
And why is the solution to a poorly bike always reg/rec??
Maybe they are just always having an identity crisis because they have two names???
Trust the girls to make the sensible comments..
This my fellow voters is why we must ensure we never let a woman in power again.
Well, at least the police and army would have fashionable and matching uniforms
If you need someone to get in the way when you put the forks back in I can assist in being a hindrance.
It's true, he is gifted in this way, or 'in THE way'....
Not as bright as the one that just appeared above your head, I will check the book of lies
How to amuze an idiot:
Look right-> <-Look Left
Old 20-05-10, 03:16 PM   #35
johnnyrod
johnnyrod's Avatar
Update:-
The man from Delmonte say (actually Alistair from Elliotts near Swindon)..anyway, he said VERY unlikely to be a battery problem. He said that as it always starts up no problem in the morning, it is actually holding charge quite well. This is supported by the fact that it will start the bike when it is hooked up to jump leads.
Feel free to call me a loser but for my 2p duff batteries can do this. Sitting there all night it can gather together enough oomf to start it, but just after a ride, if it can't store much charge, it can be pretty dead. Testing the charging system/RR is pretty easy so once that's ruled out (either fixed or OK) then what you're describing would be the battery. Duff ones can play all sorts of havoc be it poor sparking while cranking the engine, or timing/ECU hiccups. The fact the bike starts off jump leads doesn't tell you anything, it could have a dead battery and no charging system, because it's going to run entirely off the jump leads. Bottom line is, be sure what you're paying for, just sounds wrong to me. I'm not into replacing stuff willy, yea, verily, and also, nilly, but I reckon it's the battery.
Re. the fuelling, hard to say of course but could be all sorts of things as YC said earlier, if it's that rich at tickover I'd expect it to be a bit hard to start when warm. You mean you don't like spitting flames at following cars?
Old 20-05-10, 03:37 PM   #36
So after all this I was right in post #3?
Old 20-05-10, 03:52 PM   #37
Milky Bar Kid
Shhh! Unless you want battered Stretchie. Anyway, if it wasn't for your missus you wouldn't have a blade so SHURRRUUPP!!
Old 20-05-10, 03:55 PM   #38
_Stretchie_
Large Member
Isn't it past your bedtime?
Old 20-05-10, 11:56 PM   #39
gruntygiggles
DaffyGingerBint
Well, went to Weston tonight...rode there with lights off, put them on about 10 mins out of Weston after being on the road for about 90 minutes. Had to stop a few times on the way, started no problem. At Weston, started fine...in fact, started fine all night, even after being ridden up the A420 with high beam on most of the time and having to stop for a very nice policeman!
So.....looking forward to getting it to Elliotts in the morning as they'll just check it all for me. They've got a reg rec and a battery ready for it if needed, so I'll only buy what I need to replace.
Thanks for all your help guys
2012 Welsh TT
RIP Hovie baby
Old 21-05-10, 01:09 PM   #40
johnnyrod
johnnyrod's Avatar
Probably
Altering FI fuelling? TheGreyWolf SV Talk, Tuning & Tweaking 2 05-05-10 11:10 PM
CBR400 NC29 Babyblade - Fantastic condition magical_mover For Sale - Other Bikes and General biking items 1 22-01-10 09:13 AM
Fuelling problem? Toriiii33 Bikes - Talk & Issues 9 09-06-09 09:12 PM
fuelling up stanie SV Talk, Tuning & Tweaking 16 16-09-08 05:29 PM
Sorting out the fuelling. the_lone_wolf SV Talk, Tuning & Tweaking 9 13-08-07 11:18 AM
