#31 | |
Note I've done 80+ miles since fitting grips
Don't want to be the quickest; don't want to be the best; just want to be the one having the most fun. XL125Varadero -> Curvy SV650N-Y -> SV1000N-K3 -> Multistrada 1200s Twin-tastic stuff. Minister for Sustainability Aliquid prudentissimus delectabiles et intelligentes in adamasset lingua. |
#32 | |
#33 |
routing of the throttle cables. Make sure they're not trapped or chaffed through causing them to snag. After 80 miles that's enough to wear through the outer cables. Edge of the road it's easy, you've already got the tank up.
#34 |
Ok, what I'd do is undo what I did in the morning, in case over time something has moved. So I'd take those old man hand guards off to start with and see if I messed anything up there. Then I'd work my way back from the throttle, making sure the grip moves properly, checking the cable etc.
MotoGoLoco - You knows it The Shed - Suzuki GSX-R 750 K1 | Triumph Tiger 1050 K6 Fallout Bikes (VLogs, Tutorials, Bike Vids) Fallout Breakbeat (My Music) |
#35 | |
Throttle butterflies open and close when throttle opened and closed.
#36 |
do the ones above them, the vacuum operated butterflies move when the engine is on?
#37 |
Not running long enough to know but it should at least tickover even if they don't move
#38 |
unless they are in the fully closed position. They should always be 'open' to some degree. When you switch the ignition on they should fully open then return to the default angle.
#39 | |
In general butterflies and throttle action seem OK and in sync when viewed from above the airbox looking into the bodies. I need to go do other stuff now so will answer further questions tomorrow.
#40 |
So intake is good which is one demon sorted. Fuel and spark would be the next things i would look to.
Coming soon to a roadside near you. | the_lone_wolf | Bikes - Talk & Issues | 79 | 18-02-10 10:36 PM |
Roadside shrines | Magnum | Idle Banter | 32 | 15-01-09 03:24 AM |
Diagnostic plug | DavieSV | SV Talk, Tuning & Tweaking | 1 | 11-01-08 08:54 AM |
Which Roadside Recovery? | Mogs | Bikes - Talk & Issues | 20 | 08-02-05 05:32 PM |
Charging problem, need diagnostic help!!! | Troy | SV Talk, Tuning & Tweaking | 12 | 20-09-04 11:21 AM |
