#61 | |
@Barwel, who's doing your cylinder work? And is that an original shock you have there? |
#62 | |
Large Member
Got a litre bottle of 'Gunk' degreaser as needed to clean the engine bay and underside of the Disco for the MOT so just put some in a measuring jug and got a paint brush on the job. Cut the brustles a little shorter, but not too short or it'll just spray everywhere when you are brushing, but if too long you won't be able to work in it through the grease. Brush it in and spray it off with a hose, pressure washers even better Turned out really well.
How to amuze an idiot: Look right-> <-Look Left |
#63 | |
![]() and its a gsxr 1000 k3 (i think) shock cant rember what year it is exactly lol |
#64 | |
Used it on the 2 rear calipers that needed a proper clean, refurbed them a treat.
#65 | |
Large Member
#66 |
#67 |
ohh f*ck just tried the drill out the exhaust stud with a drill extractor and it faild miserably so going to tap it or heli coil it
what do you think tap or coil ? ps what size should i tap it to if im going down that rout ? M10 ? |
#68 |
When mine snapped someone more mechanically capable than me made up a block of metal which bolted on to the good bolt and was used as a guide so that the snapped stud could be drilled out. Then a tap was used to get out the last of the metal from the original threads. So don't go for a larger tap straight away
#69 | |
#70 |
Timesert is far, far better than helicoil, the local machine shop helicoiled an exhaust stud on my car and in the drilling they nicked the oil way... I've tried everything I can think of and some ideas my mates came up with and it still weeps oil, a Timesert would have been oil tight with nothing more adventurous than thread lock.
http://www.timesert.co.uk/time-sert.php |
busa piston swap | antony | SV Talk, Tuning & Tweaking | 19 | 11-12-10 07:27 PM |
Would you be the busa cop? | Warthog | Idle Banter | 29 | 02-04-10 10:14 AM |
Still a work in progress but getting there!! views please!!! | lodman27 | Photos | 23 | 04-10-08 04:41 PM |
My engine swap progress.. Essay warning.. (Now with Pics) | Daimo | SV Talk, Tuning & Tweaking | 20 | 20-08-06 05:05 PM |
My SV, a work in progress..... | Nexus242 | Photos | 4 | 23-03-06 10:25 AM |
