13-01-20, 02:21 PM | #71 |
Re: Will an R1 front master cylinder fit?
You could try a bolt and nut through the disconnected banjo end, with washers either side. You don't need the seal to be perfect, as long as it allows some pressure be developed for a second or so.
13-01-20, 06:20 PM | #72 |
I took the caliper into work and got it off with an air line. Was really easy actually. I opened the bleed valve and put a tight bit of hose on it, pushed the other end on a air gun. Had to put a bolt in the banjo hole to block it and they popped out. Had a piece of wood where the brake disc would be so they came out level. Just need to press the sliding pin out on this one now.
19-01-20, 02:20 PM | #73 |
Cheers guys I’ve done both calipers with new seals. Both calipers sliders were seized and it’s been a pain in the ass. Bikes all back together and system bled etc. Brake lever is nice and firm, but... when I push the bike I can hear the pads on the front disk. Is this normal? Doesn’t sound normal
19-01-20, 02:39 PM | #74 |
Yes, they'll push back enough when the disc is rotating waay faster
19-01-20, 03:21 PM | #75 |
Normal if they're new pads, not really if you're refitting the existing one. However check again after a few miles before worrying. What I sometimes do is try to avoid using the front brake for a bit, then stop and check that the disks are cold. If you can't do that, check that they're the same temperature.
19-01-20, 03:33 PM | #76 |
Oh that’s good to know. They are new pads. I got some ebc sintered HH pads. I am tempted to put the old ones back on though just to see the difference in what a reconditioned caliper with new HEL lines feels like. I’m being gentle on the new pads for a few hundred miles and I wouldn’t have to on the old pads. Plenty of life in them too
19-01-20, 05:10 PM | #77 | |
Get used to the feel and feedback from the brake but there is no need to be gentle, just use them normally. |
02-02-20, 01:07 PM | #78 |
Two weeks later.... my brakes are brilliant. Thanks again guys
02-02-20, 09:32 PM | #79 |
spot on
Sv1000 Front Master Cylinder On SV 650? | ryangarside | SV Talk, Tuning & Tweaking | 4 | 02-04-11 10:59 PM |
Front master cylinder | eviltwin | Stuff Wanted | 0 | 27-09-10 02:00 PM |
Front master cylinder | sniff | Stuff Wanted | 3 | 28-04-10 09:19 AM |
Front master cylinder | taggy | Stuff Wanted | 7 | 31-08-07 06:02 PM |
R1/R6 Front master Cylinder | jonnygman | SV Talk, Tuning & Tweaking | 6 | 29-04-07 01:10 PM |
