Old 11-08-07, 11:53 PM   #1
Jimbo_Bimbo
Default Rear Caliper overhaul
I've had to change rear brake pads, and have found the same problem as quite a few...brake pad pins rusted in place.
So i got a repair kit cos one of the pistons looked a bit seized. Everything was going well until i tried to undo the bolts to split the caliper. One of them stuck fast. No idea how to loosen it, tried pebetrating stuff but no use.
Question is...do i really need to split the caliper to change the piston seals and clean the pistons up? If i do, does anyone have any tips on undoing the caliper bolts?
Thanks
Jim
Old 12-08-07, 12:03 AM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: Rear Caliper overhaul
As far as iknow you'll need to split the caliper to get the pistons out (well i did) try lots of penetrating fluid and then maybe some heat might shift them
2001 SV650 in shimmerin green, Not broken anymore
Old 12-08-07, 12:36 AM   #3
squirrel_hunter
squirrel_hunter's Avatar
I've always split the caliper to do the piston and seals.
Tip wise those bolts should be torqued up (can't remember the setting) nicely coupled with the fact they are made of special metal cheese makes maintenance fun. Clean them up first before attempting anything, and if you use it every day have spare bolts unless you don't mind riding without a rear brake.
Not tried an impact driver on these bolts yet as I don't have the correct size bit. The last time they seized on me I had to take them to my mechanics, they had to use heat and sweat to get them out. The next time it happens I will be looking at the Dremel and the impact driver.
Now this might sound silly but as your changing the pads its easier to have the caliper mounted correctly before attempting those bolts. I once took the whole caliper off before I decided I wanted to split it and had a bit of fun before I stuck it back on the bike!
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 12-08-07, 12:43 AM   #4
Jimbo_Bimbo
Thanks. I'll soak em up tonight with penetrating fluid and take the blow torch to them in the morning.
Squirrel i think you're right. I undid the first one with the caliper still on the bike, but not the second..can't think why. I'll put it all back on the bike and try again
Caliper Overhaul - No Bleedin Problem I'm_a_Newbie SV Talk, Tuning & Tweaking 0 21-02-09 08:22 PM
Caliper overhaul. arcdef SV Talk, Tuning & Tweaking 114 31-01-09 04:57 PM
Caliper Overhaul Kit Cam_73 SV Talk, Tuning & Tweaking 6 16-06-08 02:32 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Rear Caliper Bikerz SV Talk, Tuning & Tweaking 15 08-03-07 09:18 AM
