23-11-19, 06:38 AM | #1 |
Junior Member
Mk 1 carb replacement
Can anyone tell me what carbs are compatible with mk1?
Looking to replace mine and noticed a shed ton of 2003> carbs online Ta Sent from my ELE-L29 using Tapatalk |
23-11-19, 08:38 AM | #2 |
Re: Mk 1 carb replacement
The 2003 onwards SV650 are fuel injected so they would have throttle bodies/injectors not carbs.
The 99-02 SV uses a (semi) downdraught type of carb (Mikuni BDSR39) and the only replacements I've heard of are for racing purposes, maybe someone else has experience... https://www.spearsenterprises.com/pr...650-1999-2002/ The 96-99 SRAD GSXR750 uses the same carb http://forums.sv650.org/showthread.php?t=64556 There are rebuild kits for the stock carbs and there are a few sets of carbs on ebay at the moment. The usual problems are stuck choke plungers, damaged screw heads (they have a JIS screw which are a bit soft) and blocked jets through being stood. The inlet rubbers can split with age causing air leaks.
2016 SV650AL7 2023 GSX-8S |
24-11-19, 03:50 AM | #3 |
Looking at the part numbers for the carb they don't appear to be shared by other bikes, though I would expect some internal parts may span models. The GSXR example above might well share things like the slide or piston valve according to Suzuki but do not expect a direct replacement of the entire mechanism.
To answer the question Keihin FCR39 and FCR41 carbs are used the SV650 though will require other modifications so are not a direct replacement, though I've not done this with either myself yet. However the bigger questions is why do you want to replace the carbs? Are you experiencing a problem? |
24-11-19, 10:19 PM | #4 |
Junior Member
Thanks fellas. Replacing due to leaking fuel through one of the seals.
25-11-19, 07:59 AM | #5 | |
more comprehensive kit from US (via ebay) https://tinyurl.com/wuzuo2e
Carb help please! | Graveyard8516 | SV Talk, Tuning & Tweaking | 1 | 29-11-17 05:54 PM |
Where to source replacement carb parts includijn screws? | Daveog | SV Talk, Tuning & Tweaking | 5 | 29-05-16 11:16 AM |
Can I use any carb model replacement engine? | Daveog | SV Talk, Tuning & Tweaking | 7 | 10-11-11 01:19 PM |
Wanted: Clocks for carb model naked + headlight and carb. | Gazdaman | Stuff Wanted | 2 | 17-03-10 03:50 PM |
pipes going to carb to carb | sv650nutter149 | SV Talk, Tuning & Tweaking | 3 | 07-09-08 10:16 PM |
