09-01-11, 01:17 PM | #61 |
Re: SH2: The Rebuild (Image Heavy)
Fair enuf. Kids are more fun
09-01-11, 03:39 PM | #62 | |
Pop back later and you'll see. But to be fair its a fairly standard swapping type of mod. |
09-01-11, 04:12 PM | #63 | |
09-01-11, 08:24 PM | #64 |
it is stig
09-01-11, 08:38 PM | #65 |
That incident happened when I didn't know what I know now, courtesy of YC.
These days I am completely anal about checking the oil, I used to rely a lot on someone else (read ex) doing things like that. The impact driver incident and subsequently having to swap an engine, in fact the whole bike rebuild had YC teaching me so much, not that confident about doing a lot, but the understanding is there.
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
09-01-11, 10:28 PM | #66 | ||
Large Member
Remember when we came down to Weston Bike night all that time ago.. It had been in boxes for about a year at that point Quote:
How to amuze an idiot: Look right-> <-Look Left |
16-01-11, 10:20 PM | #67 |
Part 10; Heads Up:
With the piston's and barrels on its time for the valves and timing is everything. Cleaned them up to remove some of the carbon build up but stopped short of removing the valves totally. With the valves heads on the cams need to go in. Remember to get the engine rotation correct before trying to put the cams in as if you don't things will not line up and if you don't check the rotation gently you can do a lot of damage. For this engine I had another rummage in the garage and came up trumps with a set of later cams to do the traditional cam swap. Using the instructions on here and on BARF I marked the old cams and installed them (more than once but lets never talk about that again) After the cams were installed valve clearances were the order of the day. The inlets were in tolerance, however the exhausts needed to drop one shim size. Note as a tip here take all of the shims out if they are going to be replaced to get the correct current sizes before ordering replacements as the shims on the front cylinder may not match the shims on the rear... Finally its the valve covers and the engine covers. The great book of lies says that the water pump on the clutch case should be taken out to facilitate the removal of the clutch cover, in hindsight I don't think this is strictly necessary, but would like to know others opinions. The valves cleaned up And on the engine The new and old cams Front timing marks Rear timing marks Make sure everything is on And then add the covers More covers And the engine assembled
"A little enthusiastic?" May I add here, GG is awesome and I think I am in love with Stretchie...he rocks my world! SH2 | 2MA | GROM | YSR Last edited by squirrel_hunter; 16-01-11 at 10:26 PM. Reason: Forgot the pictures |
16-01-11, 10:27 PM | #68 |
Thing about taking water pump off is not right, they are talking about 2gen.
16-01-11, 10:35 PM | #69 |
Looking good mate.
Found a use for an old haynes aswel!!
16-01-11, 10:37 PM | #70 |
how did you get the heads that clean ? mine have burnt oil all over them that won't come off
with my engine was black :/ |
Oban and beyond (Image heavy) | DarrenSV650S | Photos | 3 | 12-06-09 08:53 PM |
my new baby *image heavy* | Amplimator | Photos | 17 | 11-05-09 10:19 PM |
Been out for my best ride yet (image heavy) | Magnum | Photos | 26 | 11-04-09 12:08 PM |
Colchester Zoo. Very image heavy! | Jester666 | Photos | 5 | 11-08-08 07:48 AM |
70s bike day at the Ace (Image heavy) | empty | Photos | 6 | 23-07-07 03:33 PM |
