Old 05-09-09, 08:31 PM   #1
squirrel_hunter
squirrel_hunter's Avatar
Default Alternator Removal
According to the great book of lies I need to remove the alternator in order to facilitate the splitting of the crank cases. Now the first question is, do I have to?
The reason I ask is I don't have a rotor puller tool. So is there a work around for this?
The second question assumes the answer to the first is "yep, you gotta". Now I have found this thread, which gives the specifications for a removal tool (a bolt M20 x 1.5 mm pitch). And I've found them listed in a pack of 25 at Screwfix, I assume the pitch is a typo in the other thread and should read M20 x 150 mm, please correct me if I'm wrong.
But as I don't need 25 of them is there a bolt on the SV that can be used in its place or does anyone know of somewhere that will be open on a Sunday and sale these bolts separately?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 05-09-09, 08:57 PM   #2
fastdruid
fastdruid's Avatar
Default Re: Alternator Removal
Not done it myself so don't know but no it's not a typo, it's not the length (as 150mm would be) but the pitch. The pitch essentially being the distance 1 turn would screw in the bolt but is defined as the distance between two adjacent thread peaks.
http://en.wikipedia.org/wiki/Screw_t...mber_of_starts
Any decent fastener place should be able to get you just one, something like this http://coburnmyers.thomasnet.com/ite...-12-9?&seo=110 is what you want.
Druid
Old 05-09-09, 09:18 PM   #3
squirrel_hunter
Thanks for the clarification there Druid.
Thought it was wrong as all the bolts in B&Q were listing the M size followed by 150mm, 80mm, 60mm etc. Coincidently B&Q only go up to M12 bolts.
Old 05-09-09, 09:31 PM   #4
fastdruid
fastdruid's Avatar
When listed like that it assumes the 'coarse' pitch which for M20 would be 2.5 or M20-2.5, a M20-2.0 or M20-1.5 would be "fine"
See http://en.wikipedia.org/wiki/ISO_metric_screw_thread
Druid
Old 10-09-09, 12:57 PM   #5
squirrel_hunter
In the end I got one for a few quid from Wessex Fasteners after the first fasteners place I tried didn't have any.
The shop is run by a couple of old boys who were like a double act. But as soon as I asked for the bolt they replied, "Making a puller?", at last somewhere that new more than what was written in the catalogue. Just a shame they weren't open on a Sunday…
Old 10-09-09, 01:59 PM   #6
Heh, some of the "put in with the foundations" type old boys in engineering are a great source of info about all sorts of stuff, so long as you can nod with interest about tales of methanol burning velocettes and stuff
Old 11-09-09, 03:24 AM   #7
simonl
I had to take off the alternator to replace the starter clutch.
I ended up buying the proper bolt for the puller, but used a big adjustable spanner in place of a rotor holder. Just required a LOT of weight on there to loosen it, like 11 stone of body weight...
Old 11-09-09, 08:56 AM   #8
Brothers are good for something! lol
Old 12-09-09, 05:48 PM   #9
squirrel_hunter
Out of interest the proper Suzuki puller, is it just a bolt then?
And I completely agree about it needing a lot of weight. I was using a 32mm spanner locking against the table to stop the rotor from turning and then a 2ft breaker bar on the bolt. I then had to put my weight on the bar while making sure the spanner didn't slip and holding the rest of the engine in a sort of headlock arrangement to stop it from tipping over.
Not looking forward to tightening the thing back up.
Old 12-09-09, 06:54 PM   #10
TSM
The Sick Man
TSM's Avatar
just get breaker bar under load then wack it sharp and hard, the rotor will come off easier
if you have a impact drill, it will make it soooo much easier
Astravan alternator yorkie_chris Idle Banter 3 08-04-09 10:13 AM
is my alternator knackered??? stooster SV Talk, Tuning & Tweaking 22 24-10-07 06:50 AM
Chain buffer removal requires swing arm removal :-( 2mths SV Talk, Tuning & Tweaking 1 09-07-07 09:19 AM
New Alternator ... How much? The Bride SV Talk, Tuning & Tweaking 13 18-02-07 10:34 AM
alternator dead Warren SV Talk, Tuning & Tweaking 2 16-08-06 05:29 AM
