Old 23-02-16, 10:24 AM   #1
Geodude
Geodude's Avatar
Default 99 sv650 rear brake hose spring clip size?
Anyone know what size the rear res hose spring clip in the picture is please as mine seems to have rotted away. 99 sv650.
Old 23-02-16, 11:48 AM   #2
squirrel_hunter
squirrel_hunter's Avatar
Default Re: 99 sv650 rear brake hose spring clip size?
How are those clips measured?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 23-02-16, 01:14 PM   #3
you measure hose clips by the hose OD.
Geo just put a cabletie on it instead of the clip, there is very little pressure.
Old 23-02-16, 02:16 PM   #4
squirrel_hunter
I have easy access to mine at the moment. I unclipped it from the reservoir and slid it down the hose, it was still under slight tension but I measured it at 16mm. I would assume that 15mm would be what you are looking for. However I have another clip, very similar but not the exact same design that I measure at 14mm. If I were needing to replace mine I'd use the 14mm that I have as I expect it would fit.
If you want I can send it to you? Not sure how fast you need it or how difficult it would be to get one at your end.
Old 23-02-16, 07:21 PM   #5
Geodude
Geodude's Avatar
Cheers for the replies lads (i love the org always helpful) I was being tight and didnt want to order one from my dealer at £1.83p so thats why i was after approx size but Bibs super tight tip will save a few pence until i get a cheaper right size clip
Squirrel thanks very much for taking the time to help again you're a goodun. Not in a rush so no need to send anything bud but the offer was much appreciated.
Thanks lads a owe you again.
Old 23-02-16, 09:46 PM   #6
4 for £1.95
http://www.ebay.co.uk/itm/Mikalor-W1...57LoiR7nBzh0Nw
1 for £0.99 free postage (from Hong Kong!)
http://www.ebay.co.uk/itm/10X-Spring...3D221620612115
Old 23-02-16, 10:49 PM   #7
Geodude
Geodude's Avatar
Thanks Mister
Curvy SV650 rear brake caliper join seal size Alexander94 SV Talk, Tuning & Tweaking 9 15-07-15 10:36 AM
Rear brake hose clip screw corroded. Fear_My_Pixels SV Talk, Tuning & Tweaking 6 11-01-13 08:41 PM
Rear brake hose husky03 SV Talk, Tuning & Tweaking 9 09-11-07 08:28 PM
Front brake hose splitter securing bolt size? Tim in Belgium SV Talk, Tuning & Tweaking 5 12-06-07 07:53 PM
Rear brake hose clip thingy oldjack SV Talk, Tuning & Tweaking 2 09-03-07 11:35 PM
