Old 09-01-13, 12:49 PM   #51
CodeJACK
Default Re: SV special build - S-pokey-V.
Check out this guys build:
http://forums.sv650.org/showthread.php?t=189028
Maybe a turbo is an option now?
CodeJACK is offline   Reply With Quote
Old 01-02-13, 06:08 PM   #52
millemille
Been a while so here goes...
With the CBR swingarm in place used a selection of stand, jacks and clinometer to get the angles correct in order to measure up for the rear suspension linkage mount.
Then chopped away the frame cross member...
And had a mounting bracket CNC'd (as it went beyond my mandraulic machining skills) which will be welded into position in the next few weeks..
The rearesets are finished - other than getting the fasteners zinc plated and the new matrix plates anodised....
millemille is offline   Reply With Quote
Old 01-02-13, 06:19 PM   #53
millemille
On with the tank...
After a few aborted attempts managed to get the disc for mounting the Monza filler cap welded in place..
With fitting the Monza cap you need a breather valve to allow air in as the fuel level drops, otherwise wyou get vacuum lock and the bike grinds to a halt. I had a Mocal breather knocking around so ordered a weld in nut from Mocal. Unfortunately I forgot that I'm modifying a stock steel tank, not building a custom ally tank, so when the Mocal weld in nut was delivered and turned out to be ally it was no use. However, looking at it it became apparent that all it was was a turned down ally nit of the right thread for the breather. Mocal use an odd size thread on their breathers. Some quick research found that Massey Ferguson tractors use the same thread on their wheel nuts so a packet of these was ordered on ebay and a couple of them were turned down to macth the ally weld in nut for the breather...
This badboy is the fuel cell that will be welded to the back of the tank to carry the extra fuel and replace the sub frame...
..it's made from 3mm mild steel and is bomb proof. But then it will be carrying the full weight of the rider on it so needs to be.
Old 01-02-13, 06:29 PM   #54
millemille
I'd bought an SES race top fairing mount for a BMW S1000RR on the off-chance a few months back. In a blinding stroke of luck the hole centres lined up exactly with the hole centres on the SV headstock. Some spcers were turned to mate the two together...
BMW S1000RR top fairing duly offered up..
Just need to weld a couple of ally bosses to the frame tubes to accept these...
..to secure the rear of the fairing.
There's going to be an oil cooler mounted in the nose, which should be here in the next few days.
Rear caliper hanger bracket is being machined as is the sprocket/cush drive carrier - both CNC'd as they are beyond my manual machining skills....
Frame and tank welding should be complete for the end of the month.
Also scored this "veh narse" Matrix titanium steering damper...
..which, given the weight loss I've subject the bike to, and the geometry/weight distribution I'm looking for will probably be needed.
Old 01-02-13, 07:04 PM   #55
This is one cool build, I lie the BMW fairing, especially as it fits with minimal work
Old 01-02-13, 08:13 PM   #56
Same
I think it looks brilliant with the S1000rr bodywork.
Now would the headlight fit
Old 01-02-13, 10:11 PM   #57
650
650's Avatar
I'll mainly be buying this off you when it's done and you're bored of it. Kthxbye
650 is offline   Reply With Quote
Old 01-02-13, 10:21 PM   #58
Fruity-ya-ya
Talking Re: SV special build - S-pokey-V.
Wow, can't wait to see the finished article
Keep them pics coming.
Old 01-02-13, 11:07 PM   #59
squirrel_hunter
squirrel_hunter's Avatar
Cracking stuff.
Tell me more about the oil cooler you're going to be using and the fairing mounts please?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 02-02-13, 09:09 AM   #60
That tank-subframe thing is ace, you'll probably not want to support the rider on the front tank mounts though, they can crack.
gsxr build sv650nutter149 Thames Valley 21 12-05-10 07:22 AM
Hello! I have a few questions regarding a special build. NcSv SV Talk, Tuning & Tweaking 50 08-09-09 11:47 PM
For Hovis-Gid-Stretchie-Wideboy , just a special thought for you guys on this special day xXBADGERXx Idle Banter 21 24-07-09 04:26 PM
About to build one of these SV-net Idle Banter 14 22-11-08 04:14 PM
VW build quality kwak zzr Idle Banter 17 03-12-07 09:44 AM
