Old 25-05-06, 04:13 AM   #1
reb_enfilade
Default the smell of fuel when I stop?
Was wondering if anyone has any advice as I have been smelling fuel when I come to stops... I just changed the spark plugs to irridium ones and I started noticing the smell of fuel shortly after that. I dont see how new spark plugs could possibly be the cause of this?
any advice? Perhaps the smell is normal, do y'all smell a little gas when you come to stops?
Old 25-05-06, 07:08 AM   #2
Razor
Only after eating beans.
The original titel sed GAS, I'm not crazy y'know.. OK, mebbe a little bit but...
Old 25-05-06, 07:39 AM   #3
SVeeedy Gonzales
Tightened the plugs up by the recommended amount? (need to be tightened more than a re-used plug).
Installed the leads/covers on the plugs the right way round?
Anything else changed? Curvy or pointy? Had a look for any leaks? (tricky as the fuel evaporates fast). Doies the bike smell of fuel only after it's been running and not when it's been sitting for a while?
Sometimes bikes just smell of oil and fuel, especially on warmer days. mmm. Not many of them in the UK though.
Old 26-05-06, 09:38 PM   #4
sabestian
My does the same, especialy when I stop at the red light after agressive ride. I suppose it may be the fuel fumes coming from the tank vent pipe thingy. Not especialy worrying
Old 28-05-06, 09:23 AM   #5
Warren
they all do that sir.
or all the bikes ive ridden do.
Old 28-05-06, 03:52 PM   #6
squirrel_hunter
squirrel_hunter's Avatar
I get that sometimes aswell, I put it down to vapour being realsed from the tanks breather valve.
Well that and the fuel leak I had
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 28-05-06, 07:18 PM   #7
RandyO
leaks generally occur near the fuel petcock at the low point of the tank, any moisture in the tank will collect there on the inside will start rusting thru, eventually turning into a small pinhole
gas leaks out and evaporates almost as fast as it's leaking untill the hole gets bigger
when it leaks though generally you will be able to start smelling it on your pants, then you know you have a leak
Old 28-05-06, 09:57 PM   #8
mysteryjimbo
Yep, my gixxer does it too.
AR09 - Question - fuel stop(s) Supervox 2009 Annual Rideout 35 22-01-09 11:04 PM
I smell of poo! Bluepete Idle Banter 33 27-06-08 08:22 AM
Fuel light won't stop flashing. Tim in Belgium SV Talk, Tuning & Tweaking 10 05-09-07 11:06 PM
What's that smell? mister c SV Talk, Tuning & Tweaking 5 15-06-07 05:39 AM
Fuel stop **** thingy BoltonSte SV Talk, Tuning & Tweaking 2 10-08-05 02:55 PM
