Old 10-11-08, 12:07 AM   #1
squirrel_hunter
squirrel_hunter's Avatar
Default Cam Chain And Sprockets?
Not wanting to derail this thread reading it got me thinking...
If you replace the drive chain you should replace the sprockets at the same time as the new chain will wear quicker without (I have tried this and can confirm the theory). However if you were to replace the Cam Chain should you replace the Cams (as the sprockets are not listed separately)? And if not, why not, I assume the same wear theory as applied to the drive chain?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 10-11-08, 12:32 AM   #2
Default Re: Cam Chain And Sprockets?
Also replace the crank as that's got a sprocket as part of it...
But, the camchains are a different design of chain, which spend their life with splash lubrication of (relatively) clean oil. So don't need replacing so often.
Chain And Sprockets squirrel_hunter SV Talk, Tuning & Tweaking 10 19-05-09 10:28 PM
Chain and sprockets pencil shavings SV Talk, Tuning & Tweaking 32 23-09-08 10:14 AM
New Chain and sprockets? gavinsky23 SV Talk, Tuning & Tweaking 14 05-03-08 12:13 PM
chain and sprockets adey Stuff Wanted 4 27-11-05 01:26 PM
Chain & Sprockets BaggaZee SV Talk, Tuning & Tweaking 23 12-01-05 07:07 PM
