Old 20-03-09, 02:17 PM   #1
squirrel_hunter
squirrel_hunter's Avatar
Default Yet Another My Bike Doesn't Start
Yep you guessed it we've got another one...
Symptoms: Clicking from the relay/ solenoid and then the occasional attempt to turn over but it just doesn't have the power. All other lights currently working and not being a big drain on the battery once switched on as you would expect. Alarm functioning correctly (ignore my previous thread that was a red herring).
What I've Done: Replaced the battery which died yesterday (that one was fully charged) with a fully charged battery (charged over night showing c.13.5 amps). Tested the battery when turning over and it drops down to c.6 amps.
The Bike: 99 SV650S, Datatool Veto, left hand seat bolt removed to protect wiring. Reg/ rec is a pattern replacement. I assume if this is now dud then it will still start but not recharge.
I suspect the charging system, but as I can't start it I can't check that. So I'll do the wiring chafing check but can I get some suggestions on what else may be at fault please?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 20-03-09, 02:22 PM   #2
Apollo32_2000
Default Re: Yet Another My Bike Doesn't Start
have you checked the side stand switch and the clutch lever starter switch haven't malfunctioned.....
Old 20-03-09, 02:39 PM   #3
_Stretchie_
Large Member
_Stretchie_'s Avatar
AGAIN.... ???
Do you have a multimeter mate? I am presuming you do BUT if you do not I can bring one around tonight if you want.
How to amuze an idiot:
Look right-> <-Look Left
Old 20-03-09, 02:45 PM   #4
squirrel_hunter
Yes, again.
Will recheck the side stand and clutch switches but I don't think its them as I know what happens when they stop working (yes that is experience talking).
Yep got a multimeter, but feel free to stop round tonight as I won't be there.
Old 20-03-09, 02:50 PM   #5
_Stretchie_
Large Member
Yes, again.
MEOW!!!!!
I've been well pleased since you got that bike... For a change it's been you on the side of the road and me with a that works..
Eh... EH...
How'd you like that???
Old 20-03-09, 03:01 PM   #6
squirrel_hunter
True, but at least my bike see's the road.
Anyway back to ideas on getting it work again please.
Old 20-03-09, 03:08 PM   #7
_Stretchie_
Large Member
DOUBLE MEOW...
Mine does.... My bike has been on the road EVERY day, through thick and thin and regardless of the weather
since Monday....
Old 20-03-09, 09:28 PM   #8
chompy
DOUBLE MEOW...
since Monday....
ahaha since monday i like it.
Old 20-03-09, 09:31 PM   #9
_Stretchie_
Large Member
Sorry Squirell, I will stop derailing.
Can anyone help the boy out??
Old 20-03-09, 09:35 PM   #10
gettin2dizzy
Where does the clicking come from? Could be as simple as a crap ground. Have a look to check that the starter motor wiring hasn't taking a beating from something on the road. That'd give you your clicks.
My Bike Won't Start :( arcdef SV Talk, Tuning & Tweaking 34 01-02-09 08:38 PM
Help! bike doesn't start DJ828 Bikes - Talk & Issues 10 26-03-08 11:12 PM
bike won't start magicrat SV Talk, Tuning & Tweaking 9 16-02-08 02:31 PM
My Bike Won't Start! Yellow Bikes - Talk & Issues 4 01-09-07 08:31 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
