Old 12-09-09, 11:35 AM   #1
Andy Jeffries
Default Guide to replacing the crank cases?
I'm getting to the hard part of my SV rebuild project now...
Was going to drop in another engine in that I had but wanted to keep the original engine due to the low miles on it.
Anyways... the question, how hard is it to change the cases on a carb'd engine and what online guides are around? got a haynes manual but it always mamages to confuse the hell out of me!!
any help is really appriciated
Old 12-09-09, 12:13 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: Guide to replacing the crank cases?
why?? the other engine will come complete anyway
its a fair bit of work and several parts will be needed
Old 12-09-09, 12:27 PM   #3
fastdruid
fastdruid's Avatar
I don't understand why you are asking the question, if the original engine is low mileage then use that. It's a *lot* of work to rebuild an engine.
If you mean the side covers then that's easy but will (ideally) need new gaskets.
Druid
Old 13-09-09, 03:45 PM   #4
chakraist
The clutch cover is very easy to change (I did mine in about 10 minutes last week), the engine casings should be pretty easy. I can lend you a haynes manual for a while if you need a hand.
Old 13-09-09, 04:36 PM   #5
TSM
The Sick Man
TSM's Avatar
ok, so heads/cylinders/flywheel/clutch/starter all need to be taken off first to be able to split the engine casings in half, then put it back together you will need new head/clutch/alternator gaskets at least
yeh easy, can do it in 1h...
Old 14-09-09, 12:22 AM   #6
jambo
jambo's Avatar
As above really. The clutch cover / side covers can be changed easily with an 8mm socket. The main engine cases require a full strip / rebuild of the engine.
Your shout
Jambo
Old 14-09-09, 12:03 PM   #7
punyXpress
punyXpress's Avatar
If you REALLY ARE going to change the cases, do it as a pair.
They are usually machined as a pair
Now: Street Triple R
Old 14-09-09, 12:50 PM   #8
squirrel_hunter
squirrel_hunter's Avatar
Yep splitting the cases hasn't been to difficult for me so far proving you have the right tools (alternator puller, and clutch holder). Now getting them back together is another thing…
If you want any photos I’ve got loads that I took while taking mine apart and I’m about to start tearing down a spare engine to salvage the clutch and crank for my rebuild so any I don’t have can be taken here. But if it’s just the covers then that should be far simpler to do.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Pointy engine or crank cases Spikenipple Stuff Wanted 7 18-05-09 04:42 PM
Engine cases yorkie_chris For Sale - SV's and SV related items 1 09-01-09 11:47 AM
Splitting the cases yorkie_chris SV Talk, Tuning & Tweaking 7 06-12-07 09:40 AM
Painting K3 Engine cases Ratty SV Talk, Tuning & Tweaking 3 22-06-07 05:45 PM
Engine Cases yvo6 SV Talk, Tuning & Tweaking 0 02-02-07 06:17 PM
