Old 19-01-10, 07:53 AM   #1
Elio
Default Ignition fuse on SV650S
Hi guys,
I have had a problem with my SV650S 2002. It has happened 3 times in 2 days. The 10A ignition fuse blows whilst I am riding along. It doesn't seem to follow a pattern apart from I am accelerating. Has anyone had this or can they please point me as to where I should start looking.
thanks for any answers
Elio
It was a wire rubbing on the chassis. Thanks to those who replied!!
Old 19-01-10, 09:25 AM   #2
squirrel_hunter
squirrel_hunter's Avatar
Default Re: Ignition fuse on SV650S
I had the 10 amp ignition fuse blow once. Replaced it never traced a problem and it hasn’t happened since, some 2 years or so now.
However if yours is blowing regularly I would suggest you have a problem, most likely caused by the loom rubbing through and shorting somewhere. As you have a curvy, this thread has some good details of the usual places to look for loom damage. Give these places a check and take it from there…
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 19-01-10, 09:58 AM   #3
matt c
I had a similar issue on my old curvey where the alarm cabling was shorting on the frame. Like Squirrel said.
Fuse on K1 ginettav8 SV Talk, Tuning & Tweaking 1 04-06-08 11:32 AM
Ignition Fuse blowing Frogman SV Talk, Tuning & Tweaking 7 16-04-07 05:57 PM
ignition fuse keeps blowing any ideas adey SV Talk, Tuning & Tweaking 6 06-06-06 04:22 PM
Ignition fuse redeye321 SV Talk, Tuning & Tweaking 1 10-01-06 11:09 AM
Where to put the fuse box? andyaikido SV Talk, Tuning & Tweaking 1 22-11-05 10:36 PM
