Old 05-11-10, 08:43 AM   #1
SUPERSTARDJ01
Default Suspension oil and re-gassing?
How would I know if my front fork oil needs changing and rear shock re-gassing?
Old 05-11-10, 09:31 AM   #2
Dicky Ticker
Default Re: Suspension oil and re-gassing?
Every had a pogo stick?
Old 05-11-10, 09:35 AM   #3
Dicky Ticker
Do they leak,is it bottoming out,can you still alter the settings by adjustment and are they due for a service?
Old 05-11-10, 01:11 PM   #4
MattCollins
I do mine every 20,000km or once per year to keep them at their best.
Most of the time it is a quick job to pull them apart, clean them out with kero, dry the bits off, replace a couple of seals and put them back together with a fresh charge. Letting them go too long just wrecks the internals.
Old 05-11-10, 02:44 PM   #5
jambo
jambo's Avatar
I'm somewhere with MattCo on this one. Every 12,000 miles / once a year the forks get done. For the ZX6R the shock gets sent to K-tech / Kais every 2 years / 24,000 miles or so and they rebuild it from scratch for ~£100 plus postage which is I think very good value. Sadly rebuilding is not an option with the standard SV shock.
Jambo
Old 06-11-10, 01:02 AM   #6
About 10k each end for me, obviously I do my own but YMMV.
It's a case of feel when they start to feel tired, TBH a lot of OEM shocks aren't worth the hassle, you're throwing good money after bad at the back and would be better replacing the whole shock.
Suspension overhaul: MCT Suspension Stowmarket. Dicky Ticker Bikes - Talk & Issues 11 01-08-10 11:18 AM
suspension going off? breakz187 SV Talk, Tuning & Tweaking 10 13-06-09 05:49 PM
Shock 're-gassing' - Powder coating. Grinch Bikes - Talk & Issues 8 20-10-08 12:50 PM
Suspension set up Mike2165 SV Talk, Tuning & Tweaking 2 15-09-07 02:03 PM
suspension set up Ratty46 SV Talk, Tuning & Tweaking 13 07-09-07 07:43 AM
