Old 05-01-12, 01:43 AM   #1
rob_scott92
Default SV650 k1 Reg/rec... so I believe it might be a common fault then.
Hi guys, sorry if theres plenty of threads on this subject, thought it would be a hec of a lot easier just poting another to try and get a straight answer.
Basically, when the bike is cold/been sat for a few hours. when increasing revs the headlights will go brighter as they should. but when its warmed up a bit (after a few miles), the dash lights will suddenly dim, and i assume headlights too whilst riding. blipping the throttle dims the headlights when sat still.
So, what is this common fault with the reg/recs then? Ive just read some 'very brief' things searching on google, nothing that makes me say "Thats exactly whats happening" but i would like to get to the bottom of it.
I had to put a new battery on it back in november as it was being a bugger to start untill it just wouldnt turn the engine over at all! The new battery has been fine starting the bike, im just worried that its more a gradual thing that'll eat away at this battery too
Cheers in advance guys for any pointers
Old 05-01-12, 08:43 AM   #2
Geodude
Geodude's Avatar
Default Re: SV650 k1 Reg/rec.....so i believe it might be a common fault then...
Have a read through this thread and if you have a multimeter try this fault finder HTH. Seems that some curvy's eat reg/recs and some dont? mine did.
Sv650 wiring fault = lights andy-type-r SV Talk, Tuning & Tweaking 5 20-06-11 07:00 PM
Help with speedo fault (common) on pointy Maverick9999 SV Talk, Tuning & Tweaking 2 13-12-10 07:03 PM
Any common faults with SVs? Ginger500 SV Talk, Tuning & Tweaking 12 28-05-10 10:03 AM
Common problem? Gnome SV Talk, Tuning & Tweaking 6 19-06-07 10:08 PM
Common as muck ? Stig Soho Massive 15 18-10-04 12:22 PM
