Old 12-01-12, 12:02 AM   #1
Geese
Default Late Wed work
Guess what I've been up to ...
https://picasaweb.google.com/lh/phot...eat=directlink
Old 12-01-12, 12:55 AM   #2
joshwalker094
joshwalker094's Avatar
Default Re: Late Wed work
Changing brake lines?
Old 12-01-12, 01:07 AM   #3
squirrel_hunter
squirrel_hunter's Avatar
Seeing if a Honda CBR400 NC23 petrol tank looks better on the floor or on a bike?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 12-01-12, 10:07 AM   #4
Geese
Yep the NC23 tank on the floor the abandoned project bike.
Changing brake lines is right. Except the Donkey's gave me the wrong thread banjo bolt for the master cylinder.
So I had to re-thread their bolt to suit...
Old 12-01-12, 12:54 PM   #5
Re thread their bolt? Is that really a good idea?
Old 12-01-12, 12:58 PM   #6
Geese
Yes it's dodgy to rethread a bolt but I knew it was either going into the bin and wait for a bolt to be sent out.
So I took the dies at it. It was tough to rethread but I got there slowly. Out of about 12 threads it lost half of one. And after through cleaning, thread filing and ultrasonic bath cleaning I installed the bolt.
It should be ok all it needs to do is squish the copper washers so there's no leak.
Which i why i left it overnight with pressure on the lever and some paper to see if there's any leaks.
Old 12-01-12, 01:30 PM   #7
davepreston
just a side note give stewie a pm about the nc23 bits as i know hes got a nc23 project on atm
hth
dave
Old 12-01-12, 03:11 PM   #8
squirrel_hunter
hth
dave
He's not the only one with a NC23...
At the risk of vultureisum, if there are any performance parts then I would be interested to talk more.
Old 12-01-12, 11:12 PM   #9
Geese
No performance parts. Just a standard grey import with no plastics.
Old 13-01-12, 10:06 PM   #10
Geese
Just back from a very cold winter run. I could even see my breath inside my visor! Thank the lord for proper windproof bike gear.
It's all good. Beforehand I was very annoyed at the 2 stage brake lever i had. To go into detail. I would pull the lever a little the brake you could tell engaged a little. Then you just kept pulling more and more, all the time the rate of deceleration was the same...
Then suddenly the brakes bite like a shark... It really doesn't help when the forks are so soft on the SV having a non progressive brake makes them go up and down faster than a thai hooker.
But now.... Feels like a normal brake. Next stage see what sort of springs are in those forks and change the fork oil.
P.S. Gratius to the Admin who deleted my double post.
Late but oh well tactcom7 Photos 0 04-03-10 03:37 PM
late for work and bikes playing up AndyBrad SV Talk, Tuning & Tweaking 63 03-11-08 01:05 PM
Not too late northwind 2008 Annual Rideout 29 03-07-08 10:49 AM
