#1 | |
Was looking through Wikipedia (trying to remember the model designation of the V-Strom, thinking of putting its Handguards on my Z750).
Saw this Quote:
Now if I read that correctly, the V-Strom engine might be superior to the SV version, as is lighter. Anyone have any thoughts on this - any racers care to say why they don't swap one in instead of an SV one, swapping the cams over as well if that power boost is not needed?
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
Sounds a bit like bum gravy.
The engine is tweaked for midrange, and the nikasil will be refering to the current new/ one as it is the Gladius motor which has coated barrels and a crude slipper clutch of sorts (injects extra fuel in on the overrun to reduce the engine braking)
#3 | |
use nikersil or what ever, cylinders |
#4 | |
Not heard of anyone against cast iron liners TBH, nikasil is just bloody expensive when you need a rebore.
you dont rebore nikasil but all thing being equal you shouldn't ever need to as they should out last the bike,the stuff they put on the vfr800 aint called nikasil but it work the same and they recon it is good for 500k + as it is so hard it will never ware up. husqvarna use nikasil on there chain saws and its good for 500 hours use minimum,and thats only a 2 stroke chainsaw
#6 | |
As YC has said it wouldn't be legal, as the question was asked when the Gladius was launched. Chris it thought Nikasil couldn't be rebored?
So is the V-Strom cylinders superior to the SV cylinder due to the Nikasil?
It can't but that's because there's nothing to rebore, it isn't a liner it's a plating, (like chrome), which is necessarily only a fraction of a millimetre thick, if it's worn the cylinder is replated rather than rebored. Typically there's no liner at all - the plating is applied directly to the aluminiumof the barrel.
#9 | |
So not a cheap fix
#10 |
I've never actually paid for one myself so I don't know for certain, but as I understand it a replate is about £100-£120. So no, not a cheap fix - but they last well, so by the time it needs doing the extra cost of plated bores against a rebore, probably won't really be noticable when the rest of the motor needs fixing too.
SV1000 engine in 650 frame? | ojfrancis | SV Talk, Tuning & Tweaking | 7 | 02-01-11 04:43 PM |
Where are the frame and engine numbers? | hollayzfr1 | SV Talk, Tuning & Tweaking | 17 | 03-08-09 01:53 PM |
frame and engine heat | k31tha | SV Talk, Tuning & Tweaking | 13 | 23-06-09 11:39 AM |
SV engine and frame. Value? | MiniMac | SV Talk, Tuning & Tweaking | 6 | 02-12-08 02:24 PM |
K3 Engine and Frame | MiniMac | For Sale - SV's and SV related items | 11 | 02-12-08 09:55 AM |
