Old 14-03-12, 11:26 PM   #1
svv
Default Brake pad change - how?
http://www.youtube.com/watch?v=BG4bf...eature=related
hi , i done a few searches on here and on you tube but cant find any videos showing how to change brake pads on a curvy..... ive added a link above of a diffrent bike and am just making sure that a curvy is a straight forward as this before i start. thanks
Old 15-03-12, 08:03 AM   #2
Sir Trev
Sir Trev's Avatar
Default Re: Brake pad change - how?
Buy a Haynes manual. You cannot learn everything from the internet.
If you're that unsure about what you're doing do you really think you should be dismantling your brakes?
Old 15-03-12, 10:12 AM   #3
markc123
I'd post up a location and see if any friendly orger will help, or if you local good mechanic will let you watch and learn.
Pad change is quite simple on the SV with this guide: http://www.bluepoof.com/motorcycles/...nt_brake_pads/
But be aware that if the pistons are covered in cack then you could do damage forcing them back in, and what's really needed is a strip, clean and rebuild.
Old 15-03-12, 12:22 PM   #4
Scoobs
Retaining pins may cause you a bit of bother as well. They corrode in place and are a right biatch to get out.
Old 15-03-12, 03:29 PM   #5
TheRamJam
TheRamJam's Avatar
LINK
Above is just a generic video showing you the process of changing pads. Its pretty straight forward. If your still not sure then i'd suggest buying a Haynes manual as suggested by Trev and following that. Another option would be to have a fellow Orger, who's close by, to come guide you through it
HTH
Previous: Suzuki SV650S K9 - Sold
Suzuki GSXR1000 K8 - Wrote Aff
Honda Fireblade RR-9 - Sold
Yamaha MT 10 - Sold
Current Bike: Aprilia Tuono V4 Factory
TheRamJam is offline   Reply With Quote
Old 15-03-12, 03:51 PM   #6
Paul the 6th
Paul the 6th's Avatar
don't pump the brake pistons out once pads are removed - and if you do, don't under any circumstances put your fingers between the pistons to get them to pop out equally, I managed to get my fingers stuck for about 2 mins like that til I could reach some washing up liquid to get free.. Use a bit of wood or something instead, much less painful.
Old 20-03-12, 01:10 PM   #7
svv
thanks a lot for the answers and especially the links i think theyve given me what i want, plus ive got the haynes so fingers crossed
just to double check, if i take the top of the reservoir off to push the pistons back in then i just simply put the top back on before i pump the brakes with the new pads in place, its as simple as that is it? i dont have to do anything technical to create a vacuum in the res or anything do i?
Old 20-03-12, 01:31 PM   #8
markc123
When you take the top off to push the pistons, watch the level. You dont want to let it spill over. Stop and remove fluid if needed.
You can then close it, but check the level after you get it all back together and top up as needed.
No vacuum, there is a rubber diaphragm which keeps the fluid isolated from the air in the res.
Old 20-03-12, 01:37 PM   #9
svv
cheers mark let u know how it goes
Old 20-03-12, 02:09 PM   #10
I would have paid money to see this
Brake pad change - now binding JustATrick Bikes - Talk & Issues 11 22-01-12 09:14 PM
Brake fluid change on Curvy? Scythe92 SV Talk, Tuning & Tweaking 23 24-04-11 01:37 PM
When to change brake pads? steveg SV Talk, Tuning & Tweaking 25 01-10-08 08:57 PM
brake pad change - top up fluid? branny SV Talk, Tuning & Tweaking 44 20-04-06 10:12 PM
How long does it take to change a brake disc? greeno76 SV Talk, Tuning & Tweaking 6 09-02-05 01:46 PM
