Hi guys in looking at doing a major strip on my curvy sv 1 as its burning a bit of oil 2 had some bad vibes possibly crank or g box so need to strip to investigate an rectify the issue.
can anyone recommend any where to get the piston rings from as im struggling to find some. Cheers Ben |
Zoran at twf racing can get them a lot cheaper from the states I got all my stuf from him and saved almost £100
Your local Suzuki dealer would be the best bet unless you're going to be doing interesting things with it...
However I think you might be better off investigating your problems before stripping the engine down as it can start to get expensive. What are your exact problems? |
Was yours really that much cheaper? I never really costed mine up you see.
Don't they run the same size piston as the 'busa? Wouldn't those rings fit?
well its burning way too much oil at the moment seems to have lost some engine braking, valve clearances are a bit over due.
well started to vibrate a lot more than normal above 6k an box sounds a little whiny |
If the rings are the same size as the pointy, I can get them discounted from a dealer
First of all I'd check the valve clearances and adjust where needed.
Then I'd do a compression and leakdown test. Then I'd see what needs doing from those results before I'd be taking the heads off... Might even balance the carbs while I'm in there. Change the plugs, the air filter etc. Whats the service history like?
"A little enthusiastic?" May I add here, GG is awesome and I think I am in love with Stretchie...he rocks my world! SH2 | 2MA | GROM | YSR Last edited by squirrel_hunter; 02-07-12 at 10:22 PM. |
#9 | ||
All info on clearance ect hear http://forums.sv650.org/showthread.p...t=Busa+pistons Ps I ran Busa pistons with sv rings with .6thou skimmed off the bores of the sv cylinders with .7thou removed from the standard head gaskets to increase the compression Last edited by barwel1992; 02-07-12 at 10:49 PM. |
#10 | |
And like Barwel I ran Busa pistons with SV rings with the slight rebore. Not with the increased compression (well not yet anyway) but with a cam swap. Never did get it dyno'ed, must do it for the re-rebuild. |
wanted piston rings for a k5 | muzza_sv | Stuff Wanted | 8 | 12-12-11 08:47 PM |
new piston and rings! | suzuki_lady7 | SV Talk, Tuning & Tweaking | 4 | 20-10-11 09:04 AM |
Do i REALLY need to replace the piston rings? | muzikill | SV Talk, Tuning & Tweaking | 11 | 01-04-11 06:56 AM |
Piston rings k3 sv650s | muzikill | Stuff Wanted | 0 | 28-03-11 08:17 PM |
Piston rings - where from? | barwel1992 | SV Talk, Tuning & Tweaking | 4 | 05-12-10 01:22 AM |
